Problem DMZ to Inside and Inside to DMZ
rechard_david
Dear All,
Please help me, i would like to configure ASA 5510.and i had DMZ , i want DMZ can access to inside and Inside can access to DMZ, but now it doesn't work.
Pleas see configuration in the attach file.
Best Regards,
Rechard,
Jon Marshall
Hi Rechard
Not sure what the static statements are doing
static (inside,dmz) 192.168.4.0 192.168.3.0 netmask 255.255.255.0
static (dmz,inside) 192.168.3.0 192.168.4.0 netmask 255.255.255.0
You only need a static for traffic from a lower to a higher level interface. Can you remove the above 2 statements, do a "clear xlate" and then add
static (inside,dmz) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
and then retry.
Jon
Dear Jon,
it still has the problem ,
Please see in the attach file.
Best Regards,
Rechard,
hi,Rechard
please change ip address block of DMZ from 192.168.3.0 to 192.168.4.0
regards
dongdong
