Problem Hwic-4ESW 2 unit on chassis
rechard_hk
Dear All,
i have some issue with Hwic-4ESW, if i install one card(Hwich-4ESW) is working all port then i install one more card ( Hwic-4ESW) it not working.
interface and vlan is up but from my PC to port Hwic-4esw not working. what is problem on this ?
Best Regards,
Rechard
9 Replies 9
Leo Laohoo
What is the model of your router?
Dear Leolaohoo,
my cisco router is 2821 IOS
(C2800NM-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Best Regards,
Rechard
The modules can be inserted with the power still on so I guess you are looking at a hardware failure.
Have you tried reseating the module and rebooting the router?
Dear Leolaohoo,
Yes, i tried but it stilll same problem.
when i check "show ip int br" i saw Status up and protocol up but cannot ping from router to PC and PC to router.
if i change other port f0/0/0 so i can ping .
Best Regards,
Rechard
Can you please post the output "sh inventory" and "sh ip int brie"?
Dear Leolaohoo,
Please kindly see as below:
Router#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa0/0/0, Fa0/0/1, Fa0/0/2
                                                Fa0/0/3, Fa0/1/1, Fa0/1/2
                                                Fa0/1/3
2    VLAN0002                         active
3    VLAN0003                         active
4    VLAN0004                         active
209  VLAN0209                         active    Fa0/1/0
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
4    enet  100004     1500  -      -      -        -    -        0      0
209  enet  100209     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Router#sh inve
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V04 ,
NAME: "4 Port FE Switch on Slot 0 SubSlot 0", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW         , VID: V01 ,
NAME: "4 Port FE Switch on Slot 0 SubSlot 1", DESCR: "4 Port FE Switch"
For slot 0 and 4 ports is working but slot 1 not work and i try to change to other slot but the same problem.
Best Regards,
Rechard
satya mothukuri
Hi Rechard,
Please find the info regd this problem.
Prerequisites for EtherSwitch HWICs
  • Configuration of IP routing. See the Cisco IOS IP Routing: Protocol-Independent Configuration Guide for the Cisco IOS Release you are using.
  • Use of the Cisco IOS T release, beginning with Cisco IOS Release 12.3(8)T4 or later for Cisco HWIC-4ESW and Cisco HWIC-D-9ESW support. (See the Cisco IOS documentation.)
Restrictions for EtherSwitch HWICs
  • No more than two Ethernet Switch HWICs or network modules must be installed in a host router. Multiple Ethernet Switch HWICs or network modules installed in a host router will not act independently of each other. They must be stacked, as they will not work at all otherwise.
  • The ports of a Cisco EtherSwitch HWIC must not be connected to the Fast Ethernet/Gigabit onboard ports of the router.
  • There must not be inline power on the ninth port (port 8) of the HWIC-D-9ESW card.
  • There must not be Auto MDIX support on the ninth port (port 8) of the HWIC-D-9ESW card when either speed or duplex is not set to auto.
  • There must not be support for online insertion/removal (OIR) of the EtherSwitch HWICs.
  • When Ethernet Switches have been installed and configured in a host router, OIR of the CompactFlash memory card in the router must not occur. OIR of the CompactFlash memory card will compromise the configuration of the Ethernet Switches.
  • VTP pruning is not supported.
  • There is a limit of 200 secure MAC addresses per module that can be supported by an EtherSwitch HWIC.
  • Maximum traffic for a secure MAC address is 8 Mb/s.
Prerequisites for Installing Two Ethernet Switch Network Modules in a Single Chassis
A maximum of two Ethernet switch network modules can be installed in a single chassis. If two Ethernet switch network modules of any type are installed in the same chassis, the following configuration requirements must be met:
  • Both Ethernet switch network modules must have an optional Gigabit Ethernet expansion board installed.
  • An Ethernet crossover cable must be connected to the two Ethernet switch network modules using the optional Gigabit Ethernet expansion board ports.
  • Intrachassis stacking for the optional Gigabit Ethernet expansion board ports must be configured. For information about intrachassis stacking configuration, see the 16- and 36-Port Ethernet Switch Module for Cisco 2600 Series, Cisco 3600 Series, and Cisco 3700 Series feature module.
Note
Without this configuration and connection, duplications will occur in the VLAN databases, and unexpected packet handling may occur.
Please go thu this doc...
http://www.cisco.com/en/US/docs/ios-xml/ios/lanswitch/configuration/12-4/lsw-hwic-ethsw-ic.html#GUID-6CBAA5B6-FE4C-4321-BACB-796DEEE55F16
I hope your problem will be solved
Rate if it is helpful
Satya.M
Dear All,
Do you have any update on this issue?
Best Regards,
rechard
  Hello rechar  , I have the same problem with a cisco C3845 ,  Do you have news for solved this problem ?
