Trying to understand Sup-E and its function on 4507R-E
Emmanuel Farrar
I could use a little help understanding something about the Supervisor Engine module that comes with the Cisco Cat 4507R-E. While I understand the amplified use of adding other functions such as security apps, etc I am just wondering why are there 2 Sup-E modules on the switch. What can be done with this and how is it best utilized.
I am sorry if this is a rookie question, but I am a rookie and this is the first time I have even heard of this device. From what I read it is amazing though and I can't wait to work with it.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Using two supervisors on a 4507R (or 4510R) is optional.  The second supervisor is installed for redundancy.  I.e. if the primary supervisor fails, functioning continues with the second supervisor.
Emmanuel Farrar
Thanks for your reply. I figured as much but just wanted to be sure. Seeing this for the first time is a bit puzzling, lol
Sent from Cisco Technical Support Android App
