Problem in Static routing
Rock Knot
Frequent Visitor
Frequent Visitor
 hello everyone
I have setup a lab scenario to practice static routing, but I am only able to do ping on 122.27.27.35 from R1 and 122.27.27.37 from R4, and not able to ping the rest of the network like 143.32.32.122 from R4 and vice-versa.
can you please figure it out what am I doing wrong?
Thanks.
Hello
r1-r2
r3-r4
Share the same subnet 143.32.32.0/24, if you change this design so you do not have duplicate addressing it should work
Example: R1-R2 - change to 143.33.33.0/24
R1
ip route 0.0.0.0 0.0.0.0 se1/0 143.33.33.121
R4
ip route 0.0.0.0 0.0.0.0 se1/2 143.32.32.141
R2
ip route 143.32.32.0 255.255.255.0 ser1/1 122.27.27.37
R3
ip route 143.33.33.0 255.255.255.0 ser1/1 122.27.27.35
Kind Regards
Paul
M02@rt37
Hello @Rock Knot,
Problem because you have the same subnet between R1-R2 and R3-R4.
Then how R4 should route packet towards 143.32.32.122/24 since this subnet /24 is directly connected to its serial interface s1/2. And vice versa.
Modify your design, and use /30 subnet for Routers interconnection like this. You need only 2 IPs.
After that ensure on R2 and R3 you have statics routes towards the different subnets. R1 and R4, as extremity, should only have default route.
Best regards
Martin L
just FYI, you can attach your PT file here but it must be in a zip format
Regards, ML
**Please Rate All Helpful Responses **
