Problem: IP SLA - WAN Auto Failover - Single router with three Interfaces ( LAN, WAN1, WAN2)
shuja.najmee
I have a problem with my IP sla on a router with two ISPs (ISP A and ISP B). A= boradband, B= T1. I have tested the failover in the past by disabling the primary interface and it worked. Yesterday ISP A went down partially and the failover to T1 didin't happened. Maybe because the tracking was done on ISP A gateway and that IP was reachable even though the ISP A was down.
I have made some modification to my config to see if I can fix this, but it looks like unless I specify a static default route with no tracking option to my ISP A, the traffic keep going through T1.  In my current config, I have added an "P local Policy Route-MAP" and I also changed the IP being tracked to my ISP's DNS address.
Someone please review my attached config and advise what is wrong with my config. Thanks,
Shuja
term len 0
TQI-WN-RT2911#sh run
Building configuration...
Current configuration : 7720 bytes
! Last configuration change at 20:54:18 UTC Sun Oct 28 2012 by admin
! NVRAM config last updated at 20:54:18 UTC Sun Oct 28 2012 by admin
version 15.1
service password-encryption
hostname TQI-WN-RT2911
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip dhcp remember
ip domain name TQI.com
crypto pki trustpoint TP-self-signed-2562258950
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2562258950
revocation-check none
rsakeypair TP-self-signed-2562258950
crypto pki certificate chain TP-self-signed-2562258950
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
username admin privilege 15 password 7 141F13050806sdfds25242F
redundancy
track 1 ip sla 1 reachability
delay down 10 up 20
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key ############ address 173.161.255.241 255.255.255.240
crypto isakmp client configuration group EASY_VPN
key $#############
dns 10.10.0.241 10.0.0.241
domain ttqi.com
pool EZVPN-POOL
acl VPN+ENVYPTED_TRAFFIC
save-password
max-users 50
max-logins 10
netmask 255.255.255.0
crypto isakmp profile EASY_VPN_IKE_PROFILE1
   match identity group EASY_VPN
   client authentication list default
   isakmp authorization list default
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile EASY_VPN_IPSec_PROFILE1
set security-association idle-time 86400
set transform-set ESP-3DES-SHA
set isakmp-profile EASY_VPN_IKE_PROFILE1
crypto map VPN_TUNNEL 10 ipsec-isakmp
description ***TUNNEL-TO-FAIRFIELD***
set peer 173.161.255.241
match address 105
interface Loopback1
ip address 10.10.30.1 255.255.255.0
interface Tunnel1
ip address 172.16.0.2 255.255.255.0
ip mtu 1420
tunnel source GigabitEthernet0/0
tunnel destination 173.161.255.241
tunnel path-mtu-discovery
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Optonline  WAN secondary
ip address 108.58.179.205 255.255.255.248 secondary
ip address 108.58.179.202 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description T1 WAN Link
ip address 64.7.17.100 255.255.255.240
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
description LAN
ip address 10.10.0.1 255.255.255.0 secondary
ip address 10.10.0.3 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered Loopback1
tunnel mode ipsec ipv4
tunnel protection ipsec profile EASY_VPN_IPSec_PROFILE1
router eigrp 1
network 10.10.0.0 0.0.0.255
network 10.10.30.0 0.0.0.255
network 172.16.0.0 0.0.0.255
router odr
router bgp 100
bgp log-neighbor-changes
ip local policy route-map IP-SLA-ROUTE-POLICY
ip local pool EZVPN-POOL 10.10.30.51 10.10.30.199 recycle delay 65535
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map OPTIMUM-ISP interface GigabitEthernet0/0 overload
ip nat inside source route-map T1-ISP interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.10.0.220 3389 64.7.17.100 3389 extendable
ip nat inside source static tcp 10.10.0.243 25 108.58.179.202 25 extendable
ip nat inside source static tcp 10.10.0.243 80 108.58.179.202 80 extendable
ip nat inside source static tcp 10.10.0.243 443 108.58.179.202 443 extendable
ip nat inside source static tcp 10.10.0.220 3389 108.58.179.202 3389 extendable
ip nat inside source static tcp 10.10.0.17 12000 108.58.179.202 12000 extendable
ip nat inside source static tcp 10.10.0.16 80 108.58.179.205 80 extendable
ip nat inside source static tcp 10.10.0.16 443 108.58.179.205 443 extendable
ip nat inside source static tcp 10.10.0.16 3389 108.58.179.205 3389 extendable
ip route 0.0.0.0 0.0.0.0 108.58.179.201 track 1
ip route 0.0.0.0 0.0.0.0 64.7.17.97 100
ip access-list extended VPN+ENVYPTED_TRAFFIC
permit ip 10.10.0.0 0.0.0.255 any
permit ip 10.0.0.0 0.0.0.255 any
permit ip 10.10.30.0 0.0.0.255 any
ip sla 1
icmp-echo 167.206.112.138 source-interface GigabitEthernet0/0
threshold 100
timeout 200
frequency 3
ip sla schedule 1 life forever start-time now
access-list 1 permit 10.10.0.0 0.0.0.255
access-list 2 permit 10.10.0.0 0.0.0.255
access-list 100 permit ip 10.10.0.0 0.0.0.255 any
access-list 101 permit icmp any host 167.206.112.138 echo
access-list 105 remark ***GRE-TRAFFIC TO FAIRFIELD***
access-list 105 permit gre host 108.58.179.202 host 173.161.255.241
route-map T1-ISP permit 10
match ip address 100
match interface GigabitEthernet0/1
route-map OPTIMUM-ISP permit 10
match interface GigabitEthernet0/0
route-map IP-SLA-ROUTE-POLICY permit 10
match ip address 101
set ip next-hop 108.58.179.201
set interface Null0
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
TQI-WN-RT2911#
cadet alain
1)of course you need a secondary floating static route to switch traffic out to when primary goes down
2)
set interface Null0
With this config you are dropping your IP SLA probes so your track object will always be down ,so the primary route will never get installed and you will always use the secondary route even if ISPA is functional.
In your IP SLA you should ping an external address not the gateway from ISPA because the Gateway may be UP but it doesn't mean that it can forward your traffic to destination if there is a problem upstream.
With the source-interface configured in your IP SLA config you shouldn't need this local PBR anyway and you can also configure a static host route going through Primary for the external address you are monitoring if you want to replace the PBR too.
Regards.
Alain
