Problem of EIGRP
alexcjuz
HI,
I got a problem with EIGRP as the attached file.
In this file, I suppose the R2 router should be a neighbor with R1 and R3.
But as the file , they don't.
Please help me finding the problem. Thanks.
Alex
2 Accepted Solutions
Martin L
it looks like your mixed up interfaces and IPs on R2, pairs are going to wrong routers with current IPs; For a router to establish relationships they must be on the same network/subnet.
Regards, ML
**Please Rate All Helpful Responses **
in addition, you also need to announce 'network 10.1.222.0 0.0.0.31' on R2.
Attached the revised, working file.
Martin L
Regards, ML
you need to add network to neighbor under EIGRP for all three router.
alexcjuz
yes, I mixed up interfaces. The packet tracer's interface labels misleading me. Thank you.
