problem of route-map in bgp
ilovebgp4
hi!Dear all
I have implement a route-map in my bgp configration to set community attribute of the routes that will advertise to a eBGP peer.but it doesn't works : "show ip bgp community no-export" show nothing from the eBGP peer;
below is my configration:
router bgp 100
no synchronization
bgp log-neighbor-changes
aggregate-address 192.168.192.0 255.255.248.0
redistribute eigrp 100
neighbor 192.168.1.246 remote-as 200
neighbor 192.168.1.246 send-community
neighbor 192.168.1.246 route-map setcomm out
no auto-summary
access-list 101 permit ip host 192.168.192.0 host 255.255.248.0
route-map setcomm permit 10
match ip address 101
route-map setcomm permit 20
set community no-export
But after I "clear bgp *",the configration begin works.Does it mean the route-map in bgp require reestablish bgp relation to works?
Thanks a lot for your help!
Harold Ritter
This is normal behavior. You need to force the updates to be resent to the neighbor(s) whenever there is a change in your routing policies. You don't necesseraly need to reset the session for this to happen. You could rather do a "clear ip bgp soft out" on the router where the policy has been changed.
Hope this helps,
