Problem resetting RMA'ed 4451-X
Brian Green
I am trying to factory reset a 4451-X Router to the default configuration.  We've customized the config, but now when it reboots it reports a bunch of bootflash errors, then reboots again.  Is there any way we can reset this thing?  I can access the rommon mode by issuing a break on initial boot, but that's the only prompt I can get to.
Thanks!
Charles Hill
Hello bwgreen99,
Once in Rommon, change the config reg to ignore startup.
(configuration register bit 6 (0x0040) so that the startup configuration (usually in NVRAM) is ignored.)
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html
Once router is back up, copy startup into running config.
Hopefully this will get you back up.
Look in the logs for a clue to why it was rebooting.
What were your bootflash errors?
Hope this helps,
Please rate helpful posts.
Thanks.
Charles Hill
Hello bwgreen99,
Hope this helps,
Thanks.
Thanks - I was able to get into it and get it ready to go back!
Your welcome.
