Cisco 876 - Configuration for internet access urgently needed
jan_riepe
Hi everyone,
I have to configure a (very) old device - Cisco model 876 - to adapt the latest changes in our local network.
The C876 was configured and provided with passwords the last time 7 years ago. These old passwords are lost and I had to fully reset the router.
Unfortunately I am a beginner with respect to Cisco-Routers and after several days without a successfull access to the internet from local network I decided to post my request here. I would be grateful for any help. It is an easy task for an advanced Cisco-user, I assume.
I will describe the situation:
* Cisco 876 router *
- Access to the device is possible via console cabel, SDM or Cisco Configuration Assistant
- VLAN1 owns the IP 192.168.1.1, subnet is 255.255.255.0
* Internet *
- internet is available from another Router THOMSON. The C876 shall be connected via LAN with THOMSON and thus with the internet
- the complete local network shall access the internet via C876 connected to THOMSON
- THOMSON runs a gateway under IP XYZ.ABC.DEF.1, subnet 255.255.255.248
- VLAN1 shall be protected from outside attacks by a firewall
* Optional, but also important *
- a portforwarding at C876 shall be setup for 3 ports for a VoIP-device inside the local network with IP 192.168.1.25
- if possible, the VoIP-device shall be accessible from the internet directly. A global IP XYZ.ABC.DEF.5 provided from the ISP is available at THOMSON. At the moment I cannot imagine a solution with the described setup. Do you know a possible approach?
So far I have configured a VLAN2 at C876 with IP XYZ.ABC.DEF.2, subnet 255.255.255.248 and connected THOMSON there. May be this was a bad approach already? All further activities to provide internet access to the local network by this approach failed unfortunately.
I would really appreciate your support. Time is pressing a little.
Ideally you could provide a configuration-file which I can upload on the C876. But any hints are also absolutely fine!
Thanks for your support.
Best regards
Jan
Kelvin Willacey
Level 4
Level 4
Post your existing configuration.
Dear KWillacey_2,
thanks for your reply. With a little delay the configuration follows with this entry (I have deleted unrelevant information such as yahoo-server-data etc.).
Looking forward to your suggestions
Jan
Current configuration : 9581 bytes
version 12.4
no service pad
hostname router_cisco
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret
enable password
no aaa new-model
resource policy
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
parameter-map type regex sdm-regex-nonascii
 pattern [^\x00-\x80]
isdn switch-type basic-1tr6
crypto pki trustpoint TP-self-signed-3229079632
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3229079632
 revocation-check none
 rsakeypair TP-self-signed-3229079632
crypto pki certificate chain TP-self-signed-3229079632
 certificate self-signed 01
  30820244 ...
  ... F3767456
  quit
username admin privilege 15 password 0
class-map type inspect smtp match-any sdm-app-smtp
 match  data-length gt 5000000
class-map type inspect http match-any sdm-app-nonascii
 match  req-resp header regex sdm-regex-nonascii
class-map type inspect imap match-any sdm-app-imap
 match  invalid-command
class-map type inspect match-any sdm-cls-insp-traffic
 match protocol dns
 match protocol https
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol tcp
 match protocol udp
class-map type inspect match-all sdm-insp-traffic
 match class-map sdm-cls-insp-traffic
class-map type inspect match-any SDM-Voice-permit
 match protocol h323
 match protocol skinny
 match protocol sip
class-map type inspect match-all sdm-protocol-pop3
 match protocol pop3
class-map type inspect match-any sdm-cls-icmp-access
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any sdm-cls-protocol-im
 match protocol ymsgr yahoo-servers
 match protocol msnmsgr msn-servers
 match protocol aol aol-servers
class-map type inspect pop3 match-any sdm-app-pop3
class-map type inspect http match-any sdm-http-blockparam
 match  request port-misuse im
 match  request port-misuse p2p
 match  request port-misuse tunneling
 match  req-resp protocol-violation
class-map type inspect match-all sdm-protocol-im
 match class-map sdm-cls-protocol-im
class-map type inspect match-all sdm-icmp-access
 match class-map sdm-cls-icmp-access
class-map type inspect match-all sdm-invalid-src
 match access-group 100
class-map type inspect http match-any sdm-app-httpmethods
 match  request method bcopy
 match  request method bdelete
 match  request method bmove
 match  request method bpropfind
 match  request method bproppatch
 match  request method connect
 match  request method copy
 match  request method delete
 match  request method edit
 match  request method getattribute
 match  request method getattributenames
 match  request method getproperties
 match  request method index
 match  request method lock
 match  request method mkcol
 match  request method mkdir
 match  request method move
 match  request method notify
 match  request method options
 match  request method poll
 match  request method post
 match  request method propfind
 match  request method proppatch
 match  request method put
 match  request method revadd
 match  request method revlabel
 match  request method revlog
 match  request method revnum
 match  request method save
 match  request method search
 match  request method setattribute
 match  request method startrev
 match  request method stoprev
 match  request method subscribe
 match  request method trace
 match  request method unedit
 match  request method unlock
 match  request method unsubscribe
class-map type inspect match-all sdm-protocol-http
 match protocol http
class-map type inspect match-all sdm-protocol-smtp
 match protocol smtp
class-map type inspect match-all sdm-protocol-imap
 match protocol imap
policy-map type inspect sdm-permit-icmpreply
 class type inspect sdm-icmp-access
  inspect
 class class-default
  pass
policy-map type inspect http sdm-action-app-http
 class type inspect http sdm-http-blockparam
  log
  reset
 class type inspect http sdm-app-httpmethods
  log
  reset
 class type inspect http sdm-app-nonascii
  log
  reset
 class class-default
policy-map type inspect smtp sdm-action-smtp
 class type inspect smtp sdm-app-smtp
  reset
 class class-default
policy-map type inspect imap sdm-action-imap
 class type inspect imap sdm-app-imap
  log
  reset
 class class-default
policy-map type inspect pop3 sdm-action-pop3
 class type inspect pop3 sdm-app-pop3
  log
  reset
 class class-default
policy-map type inspect sdm-inspect
 class type inspect sdm-invalid-src
  drop log
 class type inspect sdm-protocol-http
  inspect
  service-policy http sdm-action-app-http
 class type inspect sdm-protocol-smtp
  inspect
  service-policy smtp sdm-action-smtp
 class type inspect sdm-protocol-imap
  inspect
  service-policy imap sdm-action-imap
 class type inspect sdm-protocol-pop3
  inspect
  service-policy pop3 sdm-action-pop3
  drop log
 class type inspect sdm-insp-traffic
  inspect
 class type inspect SDM-Voice-permit
  inspect
 class class-default
  pass
 class class-default
zone security out-zone
zone security in-zone
zone-pair security sdm-zp-self-out source self destination out-zone
 service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
 service-policy type inspect sdm-inspect
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn point-to-point-setup
 no cdp enable
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
 dsl operating-mode auto
interface FastEthernet0
 switchport access vlan 2
 no cdp enable
interface FastEthernet1
 no cdp enable
interface FastEthernet2
 shutdown
 no cdp enable
interface FastEthernet3
 shutdown
 no cdp enable
interface Vlan1
 description $FW_INSIDE$
 ip nat inside
 ip virtual-reassembly
 zone-member security in-zone
interface Vlan2
 description $FW_OUTSIDE$
 ip address XYZ.ABC.DEF.5 255.255.255.248
 ip nat outside
 zone-member security out-zone
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 2 interface Vlan2 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 100 remark SDM_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip XYZ.ABC.DEF.0 0.0.0.7 any
dialer-list 1 protocol ip permit
control-plane
line con 0
 exec-timeout 0 0
 no modem enable
line aux 0
line vty 0 4
 privilege level 15
 password
 login local
 transport input telnet ssh
scheduler max-task-time 5000
no process cpu extended
no process cpu autoprofile hog
end
The NAT configuration looks fine but I don't see a default route to the Internet. Was this omitted from the configuration? I don't have much knowledge about zone based firewalls but you can remove the configuration from the interfaces and see if that helps.
