07-31-2006 11:40 PM - edited 03-03-2019 01:31 PM
HI all,
The thing is we try to apply a policy-map "service policy output NAME" inside a PVC in the ATM0.1 interface, but no way, after it the sh run output don?t show the config change... the command is accepted withou error but is not showed in the sh run...
One more thing, if I type the sh run command before going out of the PVC config mode the change is showed, but after exit that mode and type sh run again the command is lost...
Any idea?
Thanks a lot in advance.
Cheers,
07-31-2006 11:47 PM
make sure that the bandwidth configured in your service policy does not exceed 75% of the bandwidth available on the interface (the available bandwidth can be seen with the 'show que' command, check for the line 'Available bandwidth). If the bandwidth is exceeded in your service policy, the router will not apply the service policy.
If this doesn't help, can you post your config and indicate where you are applying the service policy ?
GNT
08-01-2006 12:16 AM
HI,
The Bandwidth configured in the policy-map don?t exceed the 75% of the remaining one.
Here is the config:
class-map match-any DATOS_SENALIZACION
match ip dscp af31
class-map match-any VOZ
match ip dscp ef
class-map match-any GESTION
match ip dscp cs2
class-map match-any ROUTING
match ip precedence 6
class-map match-any DATOS-SENALIZACION
match ip dscp af31
policy-map Upstream-GigADSL
class VOZ
priority 91
class ROUTING
bandwidth 30
class DATOS-SENALIZACION
bandwidth 150
random-detect
class GESTION
bandwidth 50
class class-default
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 10.9.144.160 255.255.252.0
pvc 1/40
class-vc 2M-IPoA
inarp 1
broadcast
oam-pvc manage 5
encapsulation aal5snap
We?re trying to apply the service-policy inside the PVC:
R1(config-if-atm-vc)#service-policy output Upstream-GigADSL
Here is the result before going out the PVC mode:
R1(config-if-atm-vc)#do sh run int atm0.1
Building configuration...
Current configuration : 218 bytes
pvc 1/40
class-vc 2M-IPoA
inarp 1
broadcast
oam-pvc manage 5
end
and here is after returning to the enable mode:
R1#sh run int atm0.1
Current configuration : 177 bytes
pvc 1/40
class-vc 2M-IPoA
inarp 1
broadcast
oam-pvc manage 5
end
