Problem With 2950 swith at startup
pedram rabeti
Hi ,
I have a problem with Switch Catalyst 2950 T . At startup I see following error and SYST light blink green .
I did the update IOS  but did not change .
Please help me to solve the problem.
Thank you
Done initializing flashfs.
POST: System Board Test : Passed
POST: Ethernet Controller Test : Passed
ASIC Initialization Passed
SCHAN_HDR <CPU=0 COS=0 ECODE=0 EBIT=0
LEN=0 SRC=5 DST=0 OP=7=READ_MEM_CMD>
SCHAN_DW[0]=0x1C014000
SCHAN_DW[1]=0x03000019
SCHAN_DW[2]=0x80CBA418
SCHAN_DW[3]=0x00000018
SCHAN_DW[4]=0x802B9238
SCHAN_DW[5]=0x802B9224
SCHAN_DW[6]=0x00000010
%PLATFORM_HW-3-MEM_READ_FAILURE:
Read memory failed for memory VTABLE at index 1
SCHAN_DW[1]=0x05000001
SCHAN_DW[2]=0x80CBA398
SCHAN_DW[3]=0x80CBA470
SCHAN_DW[4]=0x00000039
POST: Loop back Test Failed on FastEthernet0/1. State:Disabled
2 Accepted Solutions
cadet alain
This is explained here and it states you should contact TAC if this reoccurs:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/system/messages/msg_desc.html#wp1048203
Alain
Ivan Shirshin
This is HW failure. Either memory is corrupted or switch has HW failure and cannot read it correctly. You should replace it.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
7 Replies 7
cadet alain
Alain
Hi ,
Thank you for  reply.
According to this description, I have to replace the device.
Best Regard
Ivan Shirshin
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Leo Laohoo
Pop the lid, clean the connecting tips of the memory.  Put it back in and pray it'll work.
Hi ,
Thank you for reply .
Where is a memory chip on the motherboard ? I Cant find it  !
Reagard
Ooops.  2950.  No.  No memory.
The memory is wielded to the mother board.   There's another method ... not "fully" recommended (but I've done it before).
Bang it a few times on the flat side.
NOTE:  I AM serious.
Leo,
But actually your idea about cleaning the tips is sound. Even if there are only chips soldered on the motherboard, there is a (admittedly remote) chance that their pins, if accessible, have become covered with dust and have thus developed some kind of coupling, impairing their function. Dusting off the pins with a brush and compressed air could do the trick...
Best regards,
Peter
