problem with 857 router and adsl
fbriski10
Hello.
I have problem with connecting 857 router to ADSL. The CD led on my router is blinking green but I can't get constant green light. Please look my attachments and help if you can see any problems.
graemeporter
Hi there,
Looks like the ADSL service is not active on the line you've got the router connected to. It's not able to detect a signal from the exchange.
Best speak to your ISP.
I had this exact same issue today, as it happens - ISP screwed up on a new provide :)
Try also :
1) Ensure your router is connected to the unfiltered socket on your microfilter
2) Replace the microfilter
3) Replace the RJ-11 cable
Hope this helps!
Kind regards
Graeme
