Spanning a Port on a router?
Borman Bravo
Hi, is it possible to configure spanning (mirroring)in an ethernet port on a 7200 router? there is no option under the interface configuration, any ideas? thanks!
5 Replies 5
Collin Clark
Starting with IOS version 12.4(20)T, you can do a packet capture on the router itself. If you're running other code, I don't know of any way to do it.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6968/ps6441/product_bulletin_c25-409474.html#wp9002099
Hope that helps.
Marwan ALshawi
try to use netflow instead which can give u lots of statistics
Thanks, Netflow is great, I use it, but what I'm trying to do here is sent all spanned traffic to an IPS device.
Hello Borman,
if you can introduce a LAN switch and do SPAN on it
You just need three free ports and a new vlan.
Hope to help
Giuseppe
Or use IOS IPS.
