Problem with a Tunnel..
Hi Guys,
This setup was working correctly before but all of a sudden it is no longer working, the basic is all 3 sites have a 877 with advipservices12.4 they all link in a mesh using SVTIs in IPSec mode.
When the Tunnel between SA and VIC is up, traffic can not flow between the sites, but if the link is down and traffic reroutes through WA the traffic can flow perfectly fine...
When i ping from the VIC to the SA router it works, but when i ping SA to VIC it fails?
Excuse the mess please especially on the SA router, it is in the middle of changing configurations, also the WA router is identical to the VIC router except IP addresses
Victoria Router:
Current configuration : 3782 bytes
version 12.4
no service pad
service password-encryption
hostname XXX06RT01
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 xxxxxx
no aaa new-model
clock timezone ACST 9 30
clock summer-time AEST recurring last Sun Oct 2:00 last Sun Mar 2:00
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.200 192.168.5.254
ip dhcp excluded-address 192.168.5.1 192.168.5.100
ip dhcp pool CLIENTS
   import all
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.254
   dns-server 192.168.1.100 192.231.203.3
   domain-name xxxxxxs.local
   lease 0 2
ip domain name xxxxx.local
ip name-server 192.168.1.100
ip name-server 192.231.203.132
ip name-server 192.231.203.3
ip inspect name FIREWALL tcp
ip inspect name FIREWALL udp
username tshadmin privilege 15 secretxxxxx
username admin secretxxxxxx
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 20000
crypto isakmp key xxxx address xxx.xxx.xxx.xxx
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec profile Site-to-Site
set transform-set ESP-3DES-SHA1
interface Tunnel2
description --- Connection to SA ---
ip address 192.168.250.14 255.255.255.252
shutdown
tunnel source Dialer1
tunnel destination xxx.xxx.xxx.xxx
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile Site-to-Site
interface Tunnel3
description --- Connection WA ---
ip address 192.168.250.18 255.255.255.252
interface ATM0
description --- ADSL to Internode ---
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description --- Ethernet to Customer ---
ip address 192.168.5.10 255.255.255.0 secondary
ip address 192.168.5.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxx@internode.on.net
ppp chap password 7 xxxxx
router rip
version 2
passive-interface Vlan1
network 192.168.5.0
network 192.168.250.0
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 120 interface Dialer1 overload
ip access-list extended FIREWALL-ACL
permit tcp any host xxx.xxx.xxx.xxx eq 22
permit esp any any
permit udp any any eq isakmp
permit gre any any
deny   tcp any any
deny   udp any any
deny   ip any any
logging 192.168.1.100
access-list 120 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 120 permit ip 192.168.5.0 0.0.0.255 any
control-plane
line con 0
login local
no modem enable
terminal-type vt100
length 25
stopbits 1
line aux 0
line vty 0 4
login local
terminal-type vt100
length 25
transport input ssh
scheduler max-task-time 5000
ntp clock-period 17175078
ntp server 121.0.0.42
webvpn context Default_context
ssl authenticate verify all
no inservice
end
South Australia
version 12.4
no service pad
service timestamps log datetime localtime
hostname XXX02RT01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxxxx
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip domain name xxxx.local
crypto pki trustpoint TP-self-signed-508106013
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-508106013
revocation-check none
rsakeypair TP-self-signed-508106013
crypto pki certificate chain TP-self-signed-508106013
certificate self-signed 01
  xxxxxx
  quit
username cisco privilege 15 secret 5 xxx
username xx privilege 15 secret 5 xxx
username admin secret 5 xxx
archive
log config
  logging enable
  notify syslog
  hidekeys
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp policy 3
encr 3des
hash md5
group 2
lifetime 20000
crypto isakmp policy 4
encr 3des
hash md5
group 2
lifetime 20000
crypto isakmp policy 5
encr 3des
hash md5
group 2
lifetime 20000
crypto isakmp policy 102
encr 3des
hash md5
group 2
lifetime 20000
crypto isakmp key xxx address xxx.xxx.xxx.xx
crypto isakmp key xxx address xxx.xxx.xxx.xx4
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map MYVPN 2 ipsec-isakmp
set peer xxx.xxx.xxx.xx
set transform-set myset
match address 102
crypto map MYVPN 4 ipsec-isakmp
match address 104
interface Tunnel0
description --- Connection to WA ---
ip address 192.168.250.1 255.255.255.252
interface Tunnel6
ip address 192.168.250.13 255.255.255.252
interface Loopback0
description --- Loopback for Terminal Server to work via crypto ---
ip address 192.168.254.1 255.255.255.0
interface ATM0
no ip address
ip nat outside
no ip route-cache cef
no ip route-cache
no ip mroute-cache
pvc 8/35
  encapsulation aal5snap
  protocol ip inarp
  protocol ppp dialer
hold-queue 224 in
interface ATM0.1 point-to-point
no ip route-cache
interface Vlan1
description --- ethernet to customer ---
ip address 192.168.1.110 255.255.255.0 secondary
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip policy route-map nonat
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp chap password xxxx
crypto map MYVPN
router rip
version 2
network 192.168.1.0
ip classless
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 100 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.100 25 xxx.xxx.xxx.xx2 25 extendable
ip nat inside source static tcp 192.168.1.100 80 xxx.xxx.xxx.xx 80 extendable
ip nat inside source static tcp 192.168.1.100 110 xxx.xxx.xxx.xx2 110 extendable
ip nat inside source static tcp 192.168.1.100 443 xxx.xxx.xxx.xx 443 extendable
ip nat inside source static tcp 192.168.1.100 1723 xxx.xxx.xxx.xx2 1723 extendable
ip nat inside source static tcp 192.168.1.101 3389 xxx.xxx.xxx.xx 3389 extendable
ip nat inside source static tcp 192.168.1.100 3389 xxx.xxx.xxx.xx 3390 extendable
ip nat inside source static tcp 192.168.1.100 4125 xxx.xxx.xxx.xx 4125 extendable
permit tcp any host xxx.xxx.xxx.xxx eq 3389
permit tcp any host xxx.xxx.xxx.xxx eq smtp
permit tcp any host xxx.xxx.xxx.xx eq www
permit tcp any host xxx.xxx.xxx.xx eq pop3
permit tcp any host xxx.xxx.xxx.xx eq 443
permit tcp any host xxx.xxx.xxx.xx eq 1723
permit tcp any host xxx.xxx.xxx.xx eq 3390
permit tcp any host xxx.xxx.xxx.xx eq 4125
permit esp any any
permit gre any any
deny   tcp any any
deny   udp any any
deny   ip any any
access-list 1 permit xxx.xxx.xxx.xxx
access-list 100 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 102 permit ip 192.168.0.0 0.0.255.255 192.168.2.0 0.0.0.255
access-list 103 permit ip 192.168.0.0 0.0.255.255 192.168.3.0 0.0.0.255
access-list 104 permit ip 192.168.0.0 0.0.255.255 192.168.4.0 0.0.0.255
access-list 105 permit ip 192.168.0.0 0.0.255.255 192.168.5.0 0.0.0.255
access-list 123 permit ip host 192.168.1.100 192.168.0.0 0.0.255.255
access-list 123 permit ip host 192.168.1.101 192.168.0.0 0.0.255.255
no cdp run
route-map nonat permit 10
match ip address 123
set ip next-hop 192.168.254.2
control-plane
banner login ^C
UNAUTHORIZED ACCESS PROHIBITED
^C
line con 0
login local
no modem enable
terminal-type vt100
length 25
stopbits 1
line aux 0
line vty 0 4
login local
terminal-type vt100
length 25
transport input ssh
ntp clock-period 17175168
ntp server 202.158.218.239
end
Peter Paluch
Hello Andrew,
Is it possible that the IP addresses on your Dialer interfaces have changed? That would at least cause the pre-share authentication to fail, as you seem to have bound the pre-shared keys to peer addresses (which is a good thing to do, of course, but whenever an endpoint's IP address change, the configuration must be updated).
Also, does the IPsec tunnel actually come up correctly? What do the show crypto isakmp sa and show crypto ipsec sa commands say? Have you tried debugging the IPsec negotiation to see if the tunnels are correctly negotiated and established? Is it actually possible to reach one endpoint from the IP address of a different endpoint?
Best regards,
Peter
paluchpeter wrote:
Hello Andrew,
Best regards,
Peter
The Dialers have static IPs from the ISP, however I will double check that.
I am unable to make any changes for the next hour as the link can not go down today, but I believe the IPSec tunnels come up correctly as RIP changes the routes etc, as well as I am able to ping from VIC to SA.. BUT can not ping SA to VIC...
I will double check the IPSec tunnels are coming up correctly with the commands you suggested
