Problem with DHCP
haji_akhundov
Hello everyone,
I'm typing in the following:
router(config)#ip dhcp excluded-address 172.16.2.0 172.16.15.255
and getting this:
% Address range contains an already reserved address.
How can I fix this issue?
Haji
Try this one: instead excluded addresses, configure
dhcp
class where you allow range of IP addresses which you want.
ip dhcp pool a-pool
   network 172.16.0.0 255.255.240.0
   default-router 172.16.15.254
   dns-server 172.16.2.1 172.16.2.2
   lease 10
   class LIMIT-DHCP-SUBNET
      address range 172.16.0.0 172.16.1.255
ip dhcp class LIMIT-DHCP-SUBNET
   remark LIMIT-SUBNET
Best Regards Please rate all helpful posts and close solved questions
20 Replies 20
Nagendra Kumar Nainar
Hi Haji,
Can you check your
dhcp
binding table to see if there is any address in this range is assigned?. You can check using
show ip dhcp binding
-Nagendra
Nagendra,
I do have some devices in that range, but they are all of type 'Manual'.
blau grana
Level 7
Level 7
try this:
router(config)#ip dhcp excluded-address 172.16.2.1 172.16.15.254
if this wont help, could do provide entire configuration of
dhcp
blau grana,
this does not help.
thanks
Milan Rai
Hey Haji,
I think you are doing wrong configuration........As we know.... there is always one broadcast & network address in each subnet.......
you are trying 2.0 which is network address and
15.255
which is broadcast address.....
And while trying to excluded the address will you try different configuration for different subnet..plz...
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.15.254
If you are doing with the subnet then go with
ip dhcp excluded-address 192.168.2.1 192.168.2.254
Dont forget to rate if this helps you
Dear Milan,
That is not an issue.
In fact, the network address and the broadcast addresses should never be assigned to hosts.
We had the following configuration before that worked fine:
      ip dhcp excluded-address 172.16.1.0 172.16.15.255
The problem was that the amount of computers has reached the available pool amount, so we had to increase the pool.
we did this:
no ip dhcp excluded-address 172.16.1.0 172.16.15.255
and now we have a huge pool and all computers on the network are able to get a proper DHCP configuration. (problem solved)
But we would still like to limit that range for now, by applying:
(this is where i get the error)
(So basically add another 255 ip addresses to the pool)
Thanks.
Hey Haji
Then that must be totally with the network pool that you are creating......
May i know what is your network pool ???/
Is that been started from 1.0 network????
If you want to use the second option of
172.16.2.0
then did created the network pool with the 2.0 network...??
Or you are just using the same network pool????
ip dhcp pool a-pool
   lease 10
ip dhcp excluded-address 172.16.2.0 172.16.15.255 (this is where i get the error)
by excluding addresses you won't add them to the pool but you will do the opposite.
i'm not aware of your subnet mask but  this is more than 255 addresses in this range.
Alain
Dear alain,
Changing FROM:
TO:
will add 255 more hosts to the pool. Correct me if I'm wrong.
yes you're correct I had misunderstood what you were explaining.
Alain
If you want to limit what is advertised, why not just change the subnet mask to
255.255.254.0
Then you'll have 510 host addresses available in the pool and you won't have to worry about exclusions.
dhcp
ip dhcp pool a-pool
   lease 10
   remark LIMIT-SUBNET
blau,
never knew about this
ip dhcp
class stuff. seems
like a cool shortcut. looking for documentation online right now...
thanks
