Problem with DHCP
haji_akhundov
Hello everyone,
I'm typing in the following:
router(config)#ip dhcp excluded-address 172.16.2.0 172.16.15.255
and getting this:
% Address range contains an already reserved address.
How can I fix this issue?
Haji
20 Replies 20
I think you know the answer to that. You would need to change the subnet mask to
255.255.252.0
for both the router and the pool, and you would need to move the lower range of the pool to
172.16.14.0
Jeff,
I can't do that. Can't change the subnet. I have other devices in the range that use static addressing.
I did resolve the problem for the moment.
I did the folowing:
ip dhcp excluded-address 172.16.2.0 172.16.5.0
ip dhcp excluded-address 172.16.6.0 172.16.15.255
and it works fine.
The problem was that I had several of these for the
172.16.5.0
network:
ip dhcp pool Samsung
   host 172.16.5.41 255.255.240.0
   client-identifier 0188.308a.xxxx.xx
   default-router 172.16.15.254
   dns-server 172.16.2.1 172.16.2.2
   netbios-node-type h-node
   lease 10
that's why the exclusion didn't work. (Although it did before. strange.)
Thanks for the input!
blau,
i've tried doing what you suggested:
it gives me the following error:
% Specified address out of pool's subnet range
when i input:
address range
172.16.0.0 172.16.1.255
Thanks.
blau,
i changed this and now it works:
address range
172.16.0.1 172.16.1.255
But look, I still have this problem:
router#show ip dhcp pool a-pool
Pool a-pool :
Utilization mark (high/low)    : 100 / 0
Subnet size (first/next)       : 0 / 0
Total addresses                : 4094
Leased addresses               : 0
Pending event                  : none
1 subnet is currently in the pool :
Current index        IP address range                    Leased addresses
172.16.5.19          172.16.0.1       - 172.16.15.254     0
No relay targets associated with
class LIMIT-DHCP-SUBNET
What should I do to reset this?
Jeff,
Sounds like a nice idea.
But can we have the two different?
ip dhcp pool lsr-pool
   network 172.16.0.0 255.255.240.0
interface GigabitEthernet0/1.2
ip address 172.16.15.254 255.255.240.0
if you have static entries, then that it is was is causing the error
solution:
conf t
no serv dhcp
add the exclusion, then activate again:
serv dhcp
