problem with EIGRP
hello, currently on my Cisco 1841 router I have configured EIGRP protocol, my problem is that all sessions simultaneously fail EIGRP and restored within seconds, all come from different sources. The IOS version is 12.4 (25g). I appreciate your help.
Mohamed Sobair
Level 7
Level 7
There could be multiple reasons for that:
1) Check if you have hardware failure, it could be a sudden hardware failure.
2) Check if you have a Link failure or a Sudden Link failure.
3) Check if you have Congestion on the Main Link between the EIGRP peers.
4) Check if you have High CPU or Memory Utilization on your Device, this could also lead to the router reset periodically the EIGRP session.
Mohamed
5 Replies 5
cadet alain
could you post your log output as well as sh run | s router ei
Regards.
Alain
Hi Cadet,
router eigrp 1600
redistribute static metric 8000 100 255 1 1500 route-map RM-RD-CPS-CCS-Route
passive-interface default
no passive-interface FastEthernet0/0.900
no passive-interface FastEthernet0/1.710
no passive-interface Tunnel32763
no passive-interface Tunnel32766
no passive-interface Tunnel32768
network 10.0.0.1 0.0.0.0
network 10.0.1.1 0.0.0.0
network 10.0.2.1 0.0.0.0
network 10.240.128.44 0.0.0.0
network 10.240.129.252 0.0.0.0
network 10.240.131.124 0.0.0.0
network 10.240.131.252 0.0.0.0
network 10.240.135.249 0.0.0.0
network 10.244.244.249 0.0.0.0
network 10.247.247.249 0.0.0.0
network 10.248.248.249 0.0.0.0
network 172.16.16.1 0.0.0.0
network 172.16.255.254 0.0.0.0
network 172.29.40.1 0.0.0.0
network 192.168.3.124 0.0.0.0
network 192.168.161.3 0.0.0.0
network 192.168.164.1 0.0.0.0
distance 171 10.248.248.250 0.0.0.0
distance 171 10.248.248.253 0.0.0.0
distance 171 10.248.248.252 0.0.0.0
no auto-summary
RT-03#sh ip int br | ex una
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0.1          192.168.161.3   YES NVRAM  up                    up
FastEthernet0/0.4          10.0.0.1        YES NVRAM  up                    up
FastEthernet0/0.900        10.240.135.249  YES NVRAM  up                    up
FastEthernet0/1.710        10.0.2.1        YES NVRAM  up                    up
FastEthernet0/1.884        190.202.93.230  YES NVRAM  up                    up
Virtual-Access5            190.202.93.230  YES TFTP   up                    up
Virtual-Access12           190.202.93.230  YES TFTP   up                    up
Virtual-Access14           190.202.93.230  YES TFTP   up                    up
Virtual-Template100        190.202.93.230  YES TFTP   down                  down
Virtual-Template150        190.202.93.230  YES TFTP   down                  down
Virtual-Template160        190.202.93.230  YES TFTP   down                  down
Virtual-Template170        190.202.93.230  YES TFTP   down                  down
Virtual-Template180        190.202.93.230  YES TFTP   down                  down
Virtual-Template200        190.202.93.230  YES TFTP   down                  down
Loopback100                192.168.164.1   YES NVRAM  up                    up
Loopback2910               172.29.10.4     YES NVRAM  up                    up
Loopback2940               172.29.40.4     YES NVRAM  up                    up
Tunnel32763                10.244.244.249  YES NVRAM  up                    up
Tunnel32766                10.247.247.249  YES NVRAM  up                    up
Tunnel32768                10.248.248.249  YES NVRAM  up                    up
router eigrp 160
El mensaje fue editado por: Javier Alberto Rivera Chavez
Hi Mohamed,
My hardware is OK.
I have multiple Links but all session fall.
no Congestion.
Cpu and Memory is ok
I wonder if there is a known bug related to this failure.
Please supply the output of show log and show ip eigrp neighbors
Mohamed Sobair
Level 7
Level 7
Mohamed
