Problem with flash in router 2801
griffith2009
When I try to copy ios to one flash in router 2801, I receive the message of  of insufficient memory, and have the follow out in the next command:
Router01#sh flash
No files on device
Router01#dir
Directory of flash:/
No files in directory
64016384 bytes total (0 bytes free)
Router01#show flash: all
No files on device
Router01#sh log
Syslog logging: enabled (11 messages dropped, 4 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 43 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: disabled, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
No active filter modules.
    Trap logging: level informational, 72 message lines logged
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Number of Heads:       8
   Number of Cylinders    490
   Sectors per Track      32
   Sector Size            512
   Total Sectors          125440
ATA CARD FORMAT
   Number of FAT Sectors  62
   Sectors Per Cluster    8
   Number of Clusters     15629
   Number of Data Sectors 125300
   Base Root Sector       232
   Base FAT Sector        108
   Base Data Sector       264
ATA MONLIB INFO
   Image Monlib size = 51064
   Disk monlib size = NA
   Name = NA
   Monlib end sector = NA
   Monlib Start sector = NA
   Monlib updated by = NA
   Monlib version = NA
Router01#sh ver
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.3(11)T7, RE
LEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Sat 30-Jul-05 09:08 by dchih
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Router01 uptime is 10 weeks, 3 days, 5 hours, 40 minutes
System image file is "flash:c2801-spservicesk9-mz.123-11.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 5.0) with 234496K/27648K bytes of memory.
Processor board ID FTX0941Y0E8
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
What i cand do?
The flash show empty
6 Replies 6
Leo Laohoo
1.  That's an old IOS.
2.  If you are going to upgrade the IOS, upgrade the ROMmon Bootstrap to 12.4(13)T6.  This will give you an additional option (among other things) to boot from USB.
3.  Format the CF using the router and copy the IOS into it using the traditional method or via a card reader.
Hi leolaohoo
The router in which i am  working is operative, I try to copy a "ios" and  when it went to finish,  gave me the message "that had insufficient  space".  I try to copy a ios and  then when you run the command  "show flash," tells me "Not files on device",  The router is  working now. when I run "dir" tells me 0 bytes free. If i restart the router i have  a problem?, What i cand do?
Regards.
Try another CF (no more than 4 Gb).
Insert the CF into the slot and format using the router.  The command is "format flash:".  This should take about 5 - 10 seconds.
Once this is complete, copy the router's IOS into CF either using CLI or using a multi-card reader.
Let's take it from there.   I'm trying to determine where the fault could be.  It could be a faulty CF reader inside the router, the CF itself or an IOS bug.
it is an Bug, we have the same problem. if you change the CF Card with the new IOS, reload the router! so you are on the save side.
Hi Martin,
Do You have the number of  BUG ?
regards
