Problem with framing type SF and linecode AMI
naeem.shah
I have 3640 and 3620 with built in DSU/CSU card. The framing on the T-1 line is running SF and AMI. I am seeing alot of frame loss on my interfaces but the vendor is saying that the line are clean based on their test. Here are the config on
3620
interface Serial0/0
bandwidth 1544
ip address 10.2.128.1 255.255.255.252
ip directed-broadcast
ip pim dense-mode
service-module t1 clock source internal
service-module t1 framing sf
service-module t1 linecode ami
service-module t1 timeslots 1-24 speed 56
3640
interface Serial0/0
bandwidth 1544
ip address 10.2.128.2 255.255.255.252
ip pim dense-mode
Are their any
If I use service-module t1 timeslots 1-24 speed 64
then I am suppose to use the command
service-module t1 data-coding inverted
any suggestion are welcome
thisisshanky
Level 11
Level 11
Even though the WIC-1DSU-T1s can be configured for 56k speed, a true 4wire 56k line has to be terminated on a WIC-1DSU-56k4. That could be the problem here.
Usually with T1 CSU/DSUs the default speed is 64kbps, so you dont have to set data coding to inverted, unless the provider asks you to do so.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
scottmac
Level 10
Level 10
You usually want to take the clock source from the Line.
Most providers supply the clock for a sync connection ... most providers also use ESF framing and b8zs line coding ... so maybe your doesn't ... but it would be unusual.
It's not part of this problem, but you'll also want to change your "bandwidth" statement down to 56000 once you get this straightened out. It does nothing as far as the physical speed goes, but it's used for metric determination if you're using a dynamic routing protocol.
Good Luck
Scott
