Problem with L-LS-19-Data-K9 License
Highnet_TSC
I have recently installed the above license for a 1900 series router using :
license boot module c1900 technology-package datak9
When I reboot the router and check the license, I get the following
Index 3 Feature: datak9
        Period left: 8  weeks 3  days
        Period Used: 1  hour  0  minute
        License Type: EvalRightToUse
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Low
I would have expected the period left to be set to lifetime.
Any help on this matter would be appreciated.
Lei Tian
Hi Duncan,
Please read the software activation for ISR G2 document:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
Once you migrate to a Lifetime RTU release, as the license keys have  changed, the RTU license restarts from time zero. This means that for  the first 60 days, the Lifetime RTU license is considered to be in  evaluation mode. The show CLI output displays the "EvalRightToUse" for  the initial 60 days. An example of this output is shown below.
HTH,
Lei Tian
