Problem with NAT config - cant reach internal web server
james
Hi all,
I hope that someone can help me with a problem I seem to have with my cisco config and NAT.
Basically I have 6 valid public IP addresses. I have assigned the first IP to the external interface of router. I have created an IP pool and assigned the last IP to the pool which is used as overload for inetrnal LAN users - dynamic NAT.
I setup static NAT for one internal server using external interface IP and that works great. I then created a static NAT for another internal server using on eif my free public IP addresses.
Now I can ping the second server from the internet and also from within LAN but not from the router itself. I cannot reach the internal server from the internet on any of the ports I opened. When I do a port check from the internet the results tell me that the ports are not closed but filtered?? Anyway main point is that i cant reach the internal web server.
I did a show ip nat translations and can see the internal webserver NAT setup correctly  - when I initiate a connection from internet to internal webserver I can see my outside public IP in the NAT table next to the correct NAT entry on port 80 - I am lost now and cant see what is wrong - can anyone help me please. Many thanks
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description #FTTH VNPT#
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no mop enabled
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
shutdown
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0/0
description LAN$FW_INSIDE$
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
interface Virtual-Template1
description $FW_OUTSIDE$
ip unnumbered FastEthernet0/0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip verify unicast reverse-path
peer default ip address pool defaultpool
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2
interface Virtual-Template2 type tunnel
ip unnumbered Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Dialer0
description #FTTH VNPT#$FW_OUTSIDE$
bandwidth 45000
ip address 113.161.100.113 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1488
ip flow ingress
ip dns view-group Primary
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1448
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username globalhome09dvb password 7 00020A010E515B1200
ppp ipcp dns request
interface Dialer1
no ip address
ip local policy route-map LocalPolicy
ip local pool defaultpool 10.123.123.1 10.123.123.40
ip forward-protocol nd
ip http server
ip http port 8080
ip http authentication local
no ip http secure-server
ip dns view Primary
ip dns view Secondary
ip dns view-list Primary
view Primary 1
ip dns view-list Secondary
view Secondary 1
ip dns server
ip nat pool VNPT-public 113.161.100.118 113.161.100.118 netmask 255.255.255.248
ip nat inside source static tcp 192.168.1.4 53389 interface Dialer0 53389
ip nat inside source static tcp 192.168.1.4 9090 interface Dialer0 9090
ip nat inside source static tcp 192.168.1.4 21 interface Dialer0 21
ip nat inside source static tcp 192.168.1.4 5500 interface Dialer0 5500
ip nat inside source static tcp 192.168.1.4 5501 interface Dialer0 5501
ip nat inside source static tcp 192.168.1.4 5502 interface Dialer0 5502
ip nat inside source static tcp 192.168.1.4 5503 interface Dialer0 5503
ip nat inside source static tcp 192.168.1.4 5504 interface Dialer0 5504
ip nat inside source static tcp 192.168.1.4 5505 interface Dialer0 5505
ip nat inside source static tcp 192.168.1.4 22 interface Dialer0 22
ip nat inside source static tcp 192.168.1.4 990 interface Dialer0 990
ip nat inside source static tcp 192.168.1.4 8181 interface Dialer0 8181
ip nat inside source static tcp 192.168.1.4 444 interface Dialer0 444
ip nat inside source static tcp 192.168.1.4 80 interface Dialer0 80
ip nat inside source list 10 pool VNPT-public
ip nat inside source static tcp 192.168.1.2 25 113.161.100.114 25 extendable
ip nat inside source static tcp 192.168.1.2 80 113.161.100.114 80 extendable
ip nat inside source static tcp 192.168.1.2 443 113.161.100.114 443 extendable
ip nat inside source static tcp 192.168.1.2 2222 113.161.100.114 2222 extendable
ip nat inside source static tcp 192.168.1.2 3389 113.161.100.114 3389 extendable
ip default-network 192.168.1.0
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended NAT
permit ip 10.123.123.0 0.0.0.255 any
permit ip 113.161.100.0 0.0.0.255 any
ip access-list extended in-from-world
permit tcp any any eq ftp
permit tcp any any range 5500 5505
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 192.168.1.0 0.0.0.255 93.107.38.0 0.0.0.255
marioderosa2008
One thing is that you are not using PAT... so you have set up a one to one mapping for all internal clients when they access the internet and you only have a pool of 8 addresses...
from what i can see you are not using overload...
i would replace the line "ip nat inside source list 10 pool VNPT-public" with "ip nat inside source list 10 interface dialer0 overload" also remove the line "permit ip 113.161.100.0 0.0.0.255 any" from ACL 10...
then on all of your static NATs, rather than using the dialer0 as the global address, you want to specify a free IP in the block of 8 (apart from IP of dialer0 of course)
so, "ip nat inside source static tcp 192.168.1.4 53389 interface Dialer0 53389" should be "ip nat inside source static tcp 192.168.1.4 53389 113.161.100.115 53389" like you have done for the 192.168.1.2 statements...
Mario
