Problem with NAT on Cisco 1841 LAB
Murillo Muniz
Hi all,
I'm stuck with an issue with my home lab.
Here are the scenario:
Have a router (cisco 1841) connected with a Modem (ISP). The modem from the provider doesn't allow me to create a static route so i'm using NAT. The router is acting as a DHCP server of my LAN.
My router have two interfaces configured:
Fa0/0 - LAN
ip address 192.168.0.1 255.255.255.0
speed 100
duplex full
ip nat inside
no shutdown
Fa0/0/0 - INTERNET (TRANSIT SEGMENT)
ip address 10.0.0.2 255.255.255.0
speed 100
duplex full
ip nat outside
no shutdown
On the modem i have the ip 10.0.0.1
So here is the strange thing:
From the router i can ping google.com(DNS and IP) using both interfaces as Source. I also ping 10.0.0.1 fine. NAT translations for this communication (FROM THE ROUTER) works fine.
I have a computer connected direct on FA0/0. From this computer i can ping 192.168.0.1 and 10.0.0.2. But i can't ping www.google.com(DNS and IP)or 10.0.0.1.
No NAT Translations are created.
BUTTTTTTTTTTTT
Sometimes this communication works but most of the time it not work properly. I had upgrade the IOS but the issue remains.
Need help with that.
Sh run is below:
Building configuration...
Current configuration : 3596 bytes
version 15.1
hostname Router
boot-start-marker
boot system flash:c1841-advsecurityk9-mz.151-4.M2.bin
boot-end-marker
logging buffered 4096
enable secret 5 $1$oyXY$nTSZ0e3otqtYxkaBahO4x/
no aaa new-model
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool LAN
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 192.168.0.1
lease 8
ip cef
ip domain name muniz
ip name-server 189.40.226.80
ip name-server 189.40.224.80
ip name-server 8.8.8.8
crypto pki trustpoint TP-self-signed-3207839765
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3207839765
revocation-check none
rsakeypair TP-self-signed-3207839765
crypto pki certificate chain TP-self-signed-3207839765
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33323037 38333937 3635301E 170D3134 30333031 32303236
  32365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32303738
  33393736 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD90 7C1EC77C 9B4B6D46 7FABA72B 3AA0CEA7 8BED542C 84D4421F B11E9BA1
  516D971F 6581F72B 4DDE65B6 F206F41B 391A4FBB 159A446E 9AAEA231 D0719E48
  8BB8138C 1C1EE51C 7CDFDBBF 7B70C2FA 1707ED7D 337ACD8C B185C1B3 161FC8A1
  F352E2B4 9977DAF1 D1FDDC13 C05BDD73 2C1D762F 13EA8865 137EC582 50EB7B11
  82AF0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 143545F6 909B61E1 641D1922 F11D6218 045ED985 06301D06
  03551D0E 04160414 3545F690 9B61E164 1D1922F1 1D621804 5ED98506 300D0609
  2A864886 F70D0101 05050003 81810028 827EB2AD AFAE6971 B8D355F0 EAEFB265
  3E13C318 E9117DD1 37BC292C 96D819E6 521A7E75 414EBB5D F43AAF13 7FE6840A
  ACA9EBD2 5534C915 FD9C5138 9C0DD6B3 4F18EA19 3D016294 B0C90D2A D51C6528
  264E8FEA 6EC3E5E2 224C4111 DF09EBD7 435E0D93 61ACDF96 54E66AF0 F8E0F0BA
  BC8DBC3C C9EDAF0C E250DB5A 99AF6D
            quit
archive
log config
  hidekeys
username murillo privilege 15 secret 5 deleted
username cisco privilege 15 secret 5 deleted
redundancy
interface FastEthernet0/0
description ## CONEXAO LAN ##
ip nat inside
ip virtual-reassembly in
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
description ## CONEXAO WAN - LIVETIM - 50MB ##
ip nat outside
speed 100
full-duplex
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list NAT interface FastEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip access-list standard NAT
permit 192.168.0.0 0.0.0.255 log
deny   any
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
login local
transport input telnet ssh
line vty 5 15
logging synchronous
login local
scheduler allocate 20000 1000
end
Okay, that usually is the issue.
Can you do a "clear ip nat translations" just in case there are any and then try using an extended acl as below. Note it may not work but i always use an extended acl for these sort of things eg.
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
no need for any deny statements in your NAT acl. Then modify the NAT statement.
Alternatively you can, if you want, use a named extended acl although i haven't used these with NAT but there is no reason why it wouldn't work.
Jon
6 Replies 6
Jon Marshall
Murillo
Try removing the log keyword from your NAT acl and retry.
Jon
Tried. But the issue remains.
Jon
Jon,
I applied the following script into my router:
no ip access-list standard NAT
no ip nat inside source list NAT interface FastEthernet0/0/0 overload
ip nat inside source list 101 interface FastEthernet0/0/0 overload
Now it's working. But sometimes worked like it was before. I'll updated this topic to see if the problem was solved.
Can you explain me why to use a extendec ACL instead of Standard?
Regards.
Murillo
All i can say is that i have always used extended acls and NAT has worked for me.
Where i have seen issues is with -
1) using the log keyword in the NAT acl
2) using "any" instead of specifying the networks in a standard acl
another regular poster on these forums has reported issues using "any" as the destination in an extended acl but i have never come across that.
Like i say, using an extended acl where you specify the source IP networks has always worked for me.
Jon
Sajid Ali
Murillo,
There is no issue with you configuration, actually issue with connected system. Because when you ping google.com via 192.168.0.1 as source address, its reachable. So please check your system DNS IP in System LAN Setting and also remove this part of your configuration from router:
