Showing results forĀ
Search instead forĀ
Did you mean:Ā
Problem with NAT
GRTO
Hi Everybody,
im havin a problem with NAT at cisco router  7206VXR (NPE-G1) processor, Software (C7200-ADVENTERPRISEK9_SNA-M), Version 12.4(6)T11
The configuration is as below:
ip nat inside source list 2688 pool Office overload
ACL 2688
10 deny ip 192.168.100.0 0.0.0.255 192.168.0.0 0.0.255.255
20 deny ip 192.168.100.0 0.0.0.255 10.10.120.0 0.0.0.255
30 permit ip 192.168.100.0 0.0.0.255 any
interface GigabitEthernet0/2.88
description gateway Vlan Office
encapsulation dot1Q 88
ip address 192.168.100.129 255.255.255.0
ip nat inside
Im havin problem only with one IP: 192.168.100.42, which it nats while communicating with host 192.168.200.75, but from ACL this communication must not do NAT. in addition, it appears as NAT static, but i have not configure static nat for no one of these IP-s
Thank you in advance
Marwan ALshawi
Can you do clear ip nat translation *
then enable debug ip nat detail
And make a new session from that host/ip and post it here
By the way the clear ip nat will rest all active sessions !
Marwan
Can i ask a favour. Can you take a look at this thread for me -
https://supportforums.cisco.com/thread/2099823?tstart=30
you are better at these more complex NAT setups than i am and i am bit busy to lab it up.
Jon
