problem with packet tracer simple network 2.1.1
hello every one
i have connectivity problem with cisco packet tracer simple network 2.1.1 i do every thing right but doesn't work
thank you
13 Replies 13
Martin L
u can attach your pt file in a zip format here; we have no idea what is that 2.1.1
Regards, ML
**Please Rate All Helpful Responses **
2.1.1 it's a cisco packet tracer simple network i have connectivity problem
where is the file ?  we do not have access to that file ; u could share it here as a attachment
Regards, ML
Blue_Bird
I suggest you to provide/share the screen shot of the network topology....
it is the lab assessment in Introduction to Cybersecurity Course....
You need to complete the labs according the given instructions....
it is showing not completed means...you missed few steps....
Take your time....try again and try to complete the lab according to the instructions....
You must complete all steps.....Sure....you can compete....
Martin L
First, this PTA is not grading properly; I got IP on PC and both PC and laptop ping ping cisco.srv OK.
At least I could not get any movement on progress of completion; it is stuck on 0. The instructions are set to be range 192.168.0.x /24.  You may try other ranges to get completion moving but that would take some time.
To get IP on PC, you must do ipconfig /release then /renew on laptop.
UPDATE: Fix names of PC and laptop to get 100%; PC should start first; then laptop;  it wont get 100% other way
Regards, ML
hello sir first of all thank for your time
i do every thing they told me but nothing work
please help me i can't move on
Rename PC0 to PC and Laptopx to Laptop; attached is my solved with 100%
Regards, ML
Blue_Bird
Please go throgh the video...
https://www.youtube.com/watch?v=sEzNlJXvT18
hopefully... you can fix the problems....
Best regards
******* If This Helps, Please Rate *******
