11-29-2019 09:58 AM
Hello guys.
I have an strange problem wit ASA 5510 NAT settings.
We have one local network:
object network Local_Office_Network
subnet 172.16.0.0 255.255.248.0
description Local Network
and one ISP: 134.17.5.142
The main problem when I try to setup PAT to specific server inside the local network from outside:
object network RocketPAT
nat (inside,mts-out) static interface no-proxy-arp service tcp https 8443
It's not work, I always saw in Debug logging:
7 | Nov 29 2019 | 19:45:33 | 710005 | 178.127.193.130 | 56795 | 134.17.5.142 | 8443 | TCP request discarded from 178.127.193.130/56795 to mts-out:134.17.5.142/8443 |
I will give the main parts of the configuration below:
host 172.16.0.100
access-list Beltelecom_access_in extended permit tcp any object Rocket_Server eq https log debugging
nat (Wifi,mts-out) source dynamic any interface
nat (any,any) source static VPN VPN destination static Local_Office_Network Local_Office_Network
nat (CORP,inside) source static any any dns no-proxy-arp route-lookup
nat (inside,mts-out) source dynamic any interface
Could you tell me what is wrong. Thanks in advance!
Solved! Go to Solution.
11-30-2019 10:54 AM
sorry for asking: when you say it doesn't work from home, I guess you are not connected to the ASA through the webvpn from home ?
11-30-2019 11:54 AM
Hello
Can you try and move the default nat rule to the end of the nat config and test again please, keeping you static pat applied::
no nat (inside,mts-out) source dynamic any interface
nat (inside,mts-out) after-auto source dynamic any interface
11-30-2019 04:23 PM - edited 11-30-2019 04:41 PM
Same behavior:
7 | Dec 01 2019 | 02:10:49 | 710005 | 178.127.181.1 | 56141 | 134.17.5.142 | 8443 | TCP request discarded from 178.127.181.1/56141 to mts-out:134.17.5.142/8443 |
AnyConnect Portal works fine: https://134.17.5.142/+CSCOE+/logon.html
The following is a complete ASA configuration. Thus, the inside is connected directly to the Catalyst router, where there is a vlan with this IP address. The outside interface receives the address and the static route automatically.
+ NO any static routes
Gateway of last resort is 134.17.4.1 to network 0.0.0.0 C 172.16.8.0 255.255.255.0 is directly connected, Wifi C 172.16.0.0 255.255.255.0 is directly connected, inside S 172.16.100.10 255.255.255.255 [1/0] via 134.17.4.1, mts-out C 134.17.4.0 255.255.252.0 is directly connected, mts-out d* 0.0.0.0 0.0.0.0 [1/0] via 134.17.4.1, mts-out
Judging by the packet tracer, any request that comes from the outside interface does not fall into the NAT rules.
Result of the command: "sh run" : Saved : ASA Version 9.1(3) ! hostname domain-name enable names ip local pool Office_VPN 172.16.100.10-172.16.100.200 mask 255.255.255.0 ! interface Ethernet0/0 nameif inside security-level 100 ip address 172.16.0.1 255.255.255.0 ! interface Ethernet0/1 speed 1000 nameif mts-out security-level 0 ip address dhcp setroute ipv6 enable ! interface Ethernet0/2 nameif Wifi security-level 0 ip address 172.16.8.1 255.255.255.0 ! interface Ethernet0/3 shutdown nameif CORP security-level 0 ip address 10.0.0.1 255.255.255.0 ! interface Management0/0 shutdown nameif management security-level 100 ip address dhcp setroute ! ftp mode passive clock timezone EEST 2 clock summer-time EEDT recurring last Sun Mar 2:00 last Sun Oct 3:00 dns domain-lookup inside dns domain-lookup mts-out dns server-group DefaultDNS name-server 172.16.0.254 domain-name same-security-traffic permit inter-interface same-security-traffic permit intra-interface object network Local_Office_Network subnet 172.16.0.0 255.255.255.0 description Local Network object network VPN_Minsk subnet 172.16.100.0 255.255.255.0 description VPN_Minsk object network VPN subnet 172.16.100.0 255.255.255.0 object network VPN1 subnet 172.16.100.0 255.255.255.0 object network SVN-EXT host 172.16.0.250 object network obj_172.16.0.250 host 172.16.0.250 object network SVN-NAT host 172.16.0.250 object network SVN_NAT host 172.16.0.250 object network RocketChat host 172.16.0.100 object-group protocol TCPUDP protocol-object udp protocol-object tcp object-group service DM_INLINE_SERVICE_2 service-object icmp echo service-object icmp echo-reply service-object icmp6 echo service-object icmp6 echo-reply service-object icmp6 unreachable access-list inside_access_in extended permit ip object Local_Office_Network any access-list inside_access_in extended permit ip object VPN_Minsk any access-list inside_access_in extended permit icmp any any access-list inside_access_in extended permit ip any interface CORP access-list Beltelecom_access_in extended permit ip any any access-list Beltelecom_access_in extended permit tcp any any eq www access-list Beltelecom_access_in extended permit object-group DM_INLINE_SERVICE_2 any any access-list Beltelecom_access_in extended permit tcp any interface mts-out eq 8443 access-list Beltelecom_access_in extended permit tcp any interface mts-out eq 8081 access-list Beltelecom_access_in extended permit tcp any any eq 9000 access-list Office_Allowed remark Jira/Bamboo/BitBucket access-list Office_Allowed standard permit 172.16.0.0 255.255.255.0 access-list Wifi_access_in extended permit ip any any access-list nonat_rule extended permit ip 172.16.100.0 255.255.255.0 172.16.0.0 255.255.255.0 access-list nonat_rule extended permit ip any object VPN_Minsk access-list mts-out_access_in extended permit ip any any access-list mts-out_access_in extended permit ip any interface mts-out access-list mts-out_access_in extended permit object-group TCPUDP any object SVN-EXT eq www access-list Sound extended permit ip any object SVN-EXT access-list outside-access-inside extended permit tcp any host 172.16.0.250 eq 8080 access-list sound standard permit host 172.16.0.250 access-list global_mpc extended permit ip any any pager lines 24 logging enable logging list auth level debugging logging asdm auth logging debug-trace logging class auth asdm informational logging class vpn asdm informational logging class ssl asdm informational flow-export destination inside 172.16.0.115 2055 mtu inside 1500 mtu mts-out 1480 mtu Wifi 1500 mtu CORP 1500 mtu management 1500 no failover icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-714.bin no asdm history enable arp timeout 14400 no arp permit-nonconnected nat (Wifi,mts-out) source dynamic any interface nat (CORP,inside) source static any any dns no-proxy-arp route-lookup ! object network RocketChat nat (inside,mts-out) static interface service tcp https 8443 ! nat (inside,mts-out) after-auto source dynamic any interface access-group inside_access_in in interface inside access-group Beltelecom_access_in in interface mts-out access-group Wifi_access_in in interface Wifi timeout xlate 3:00:00 timeout pat-xlate 0:00:30 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00 timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute timeout tcp-proxy-reassembly 0:01:00 timeout floating-conn 0:00:00 ldap attribute-map Group_Check map-name memberOf IETF-Radius-Class dynamic-access-policy-record DfltAccessPolicy aaa authentication http console LOCAL aaa authentication serial console LOCAL aaa authentication ssh console LOCAL aaa authentication telnet console LOCAL aaa authorization command LOCAL http server enable http 172.16.0.0 255.255.255.0 inside http 0.0.0.0 0.0.0.0 mts-out http 0.0.0.0 0.0.0.0 inside http redirect mts-out 80 no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart sysopt noproxyarp inside sysopt noproxyarp mts-out sysopt noproxyarp management telnet timeout 5 ssh 172.16.0.0 255.255.255.0 inside ssh timeout 5 ssh key-exchange group dh-group1-sha1 console timeout 0 no vpn-addr-assign dhcp no ipv6-vpn-addr-assign aaa no ipv6-vpn-addr-assign local dhcp-client client-id interface management dhcpd address 172.16.8.10-172.16.8.254 Wifi dhcpd dns 8.8.8.8 8.8.4.4 interface Wifi dhcpd enable Wifi ! dhcpd address 10.0.0.10-10.0.0.100 CORP dhcpd dns 172.16.0.254 8.8.8.8 interface CORP dhcpd enable CORP ! threat-detection basic-threat threat-detection statistics access-list no threat-detection statistics tcp-intercept ntp server 82.209.245.153 ssl encryption aes256-sha1 aes128-sha1 3des-sha1 dhe-aes128-sha1 dhe-aes256-sha1 ssl trust-point Global_External mts-out webvpn enable mts-out anyconnect-essentials anyconnect profiles New disk0:/new.xml anyconnect enable tunnel-group-list enable tunnel-group-preference group-url group-policy SSL_VPN internal group-policy SSL_VPN attributes dns-server value 172.16.0.254 vpn-simultaneous-logins 10 vpn-idle-timeout none vpn-session-timeout none vpn-tunnel-protocol ssl-client split-tunnel-policy tunnelspecified split-tunnel-network-list value Office_Allowed default-domain value strikerz-inc.com split-tunnel-all-dns disable address-pools value Office_VPN smartcard-removal-disconnect enable webvpn anyconnect ssl rekey time none anyconnect profiles value New type user anyconnect ask none default anyconnect customization value DfltCustomization always-on-vpn profile-setting group-policy DfltGrpPolicy attributes dns-server value 172.16.0.254 vpn-tunnel-protocol ikev1 l2tp-ipsec default-domain value strikerz-inc.com group-policy GroupPolicy1 internal group-policy GroupPolicy1 attributes vpn-tunnel-protocol ssl-clientless group-policy SOUND internal group-policy SOUND attributes wins-server none dns-server value 8.8.8.8 vpn-simultaneous-logins 3 vpn-idle-timeout 30 vpn-tunnel-protocol ssl-client split-tunnel-policy tunnelspecified split-tunnel-network-list value sound webvpn deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information. username vpnm password Mu2HvbX9xenLqIVHN2gY1A== nt-encrypted username enerotov password U1oi5DrUcrFD.sS8 encrypted privilege 15 tunnel-group DefaultRAGroup general-attributes address-pool (inside) Office_VPN address-pool Office_VPN default-group-policy SSL_VPN tunnel-group DefaultWEBVPNGroup general-attributes address-pool Office_VPN tunnel-group SSL_VPN type remote-access tunnel-group SSL_VPN general-attributes address-pool (inside) Office_VPN address-pool Office_VPN authentication-server-group AD LOCAL default-group-policy SSL_VPN tunnel-group SSL_VPN webvpn-attributes group-alias strikerz-office enable tunnel-group SOUND type remote-access tunnel-group SOUND general-attributes address-pool Office_VPN authentication-server-group AD default-group-policy SOUND tunnel-group SOUND webvpn-attributes group-alias sound enable ! class-map global-class match access-list global_mpc class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum client auto message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp inspect ip-options policy-map global-policy class global-class flow-export event-type all destination 172.16.0.115 ! service-policy global_policy global : end
11-30-2019 04:46 PM
Hello
@zero_cool83 wrote:
(172.16.0.2 is the LAN IP address of the Catalyst master router). Thus, the inside is connected directly to the Catalyst router, where there is a vlan with this IP address.
Post the config of that catalyst router( I assume its L3 switch)
11-30-2019 05:01 PM
cisco WS-C3750G-24TS-1U config:
sw01-main#sh run Building configuration... Current configuration : 3882 bytes ! version 12.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname sw01-main ! boot-start-marker boot-end-marker ! enable secret 5 ******************** enable password ******************** ! username ************** privilege 15 password 0 *************** ! ! no aaa new-model switch 2 provision ws-c3750g-24ts-1u system mtu routing 1546 vtp domain Cisco vtp mode transparent ip routing no ip icmp rate-limit unreachable ip name-server 172.16.0.254 ip dhcp excluded-address 172.16.0.1 172.16.0.159 ip dhcp excluded-address 172.16.0.181 172.16.0.254 ! ip dhcp pool vl105 import all network 172.16.0.0 255.255.255.0 default-router 172.16.0.1 dns-server 172.16.0.254 ! ! ! ! crypto pki trustpoint TP-self-signed-3421512064 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-3421512064 revocation-check none rsakeypair TP-self-signed-3421512064 ! ! crypto pki certificate chain TP-self-signed-3421512064 ........ ! ! ! spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! ! ip ssh source-interface Vlan1 ! ! ! interface GigabitEthernet2/0/1 ! interface GigabitEthernet2/0/2 ! interface GigabitEthernet2/0/3 ! interface GigabitEthernet2/0/4 ! interface GigabitEthernet2/0/5 ! interface GigabitEthernet2/0/6 ! interface GigabitEthernet2/0/7 ! interface GigabitEthernet2/0/8 ! interface GigabitEthernet2/0/9 ! interface GigabitEthernet2/0/10 ! interface GigabitEthernet2/0/11 ! interface GigabitEthernet2/0/12 ! interface GigabitEthernet2/0/13 ! interface GigabitEthernet2/0/14 ! interface GigabitEthernet2/0/15 ! interface GigabitEthernet2/0/16 ! interface GigabitEthernet2/0/17 ! interface GigabitEthernet2/0/18 ! interface GigabitEthernet2/0/19 ! interface GigabitEthernet2/0/20 ! interface GigabitEthernet2/0/21 ! interface GigabitEthernet2/0/22 ! interface GigabitEthernet2/0/23 ! interface GigabitEthernet2/0/24 ! interface GigabitEthernet2/0/25 ! interface GigabitEthernet2/0/26 ! interface GigabitEthernet2/0/27 ! interface GigabitEthernet2/0/28 ! interface Vlan1 ip address 172.16.0.2 255.255.248.0 ! ip classless ip route 172.16.0.0 255.255.248.0 172.16.0.1 ip http server ip http secure-server ! ! access-list 1 permit any ! ! ! line con 0 line vty 0 4 access-class 1 in exec-timeout 30 0 privilege level 15 password 123456 login local transport preferred ssh transport input ssh line vty 5 15 password login ! end
11-30-2019 05:17 PM - edited 11-30-2019 05:18 PM
Hello
Suggest you make this switch a host switch by disabling ip routing and putting the dhcp scope for this subnet on the ASA, but in the mean time
no ip route 172.16.0.0 255.255.248.0 172.16.0.1
ip route 0.0.0.0 0.0.0.0 vlan 1 172.16.0.1
11-30-2019 05:51 PM
After adding this (in that order):
object network Rocket nat (any,mts-out) static interface service tcp 3000 8443 ! nat (inside,mts-out) after-auto source dynamic Local_Office_Network interface nat (inside,mts-out) after-auto source static any any
Now I can see the normal traffic between outside/inside (!!!):
But I still can't reach from outside (from my home): http://134.17.5.142:8443/
11-30-2019 04:55 PM
Interesting picture, I just replaced outside IP in the packet tracer on the my white IP:
12-01-2019 02:57 AM - edited 12-01-2019 03:13 AM
Hello
as I have stated from your OP the static nat statement for that host was okay and with that original any any in your nat acl it was looking like your static nat wasn’t the problem -even though it wasnt a secure way of doing nat
since then you have added-removed various configuration .so it’s hard to understand the current status
Lastly you have now shown a L3 device attachied on the lan interface of a the asa which has the incorrect routing for a lan host resides on the L3 switch
what needs to be accomplished is you need to establish basic connectivity from your lan this through the asa before anything else
So to start change the default of the L3 switch and test connection to the asa and then next to the internet via that dynamic NAT statement I asked you to add - remove all over additional nat statements if not required then we can work through your issue in a defined manner
12-01-2019 06:21 AM
something is misconfigured in your network. Have a look at the output below:
SW01
ip dhcp pool vl105
import all
interface Vlan1
ASA
nameif inside
security-level 100
ospf cost 10
ospf authentication null
--> There is no IP address 172.16.0.1 on your layer 3 switch. Also, the subnet masks on the firewall and the Vlan 1 interface do not match. The DHCP pool is named Vl105, does that mean it is supposed to serve Vlan 105 ?
I don't know what your topology looks like, but what is the purpose of the layer 3 switch when you only have one Vlan, Vlan 1, configured ?
Also, on the ASA, the inside interface has a partial OSPF configuration, what is that for ?
12-01-2019 07:36 AM
So, I deleted all the unused NAT rules. Now I see the following picture, where 178.127.181.1 (my home ext IP) 172.16.0.100 (internal server)
"packet-tracer input mts-out tcp 178.127.181.1 8888 172.16.0.100 3000" Phase: 1 Type: ROUTE-LOOKUP Subtype: input Result: ALLOW Config: Additional Information: in 172.16.0.0 255.255.255.0 inside Phase: 2 Type: ACCESS-LIST Subtype: log Result: ALLOW Config: access-group Beltelecom_access_in in interface mts-out access-list Beltelecom_access_in extended permit tcp any any object-group DM_INLINE_TCP_1 object-group service DM_INLINE_TCP_1 tcp port-object eq 8888 port-object eq 3000 Additional Information: Phase: 3 Type: NAT Subtype: per-session Result: ALLOW Config: Additional Information: Phase: 4 Type: IP-OPTIONS Subtype: Result: ALLOW Config: Additional Information: Phase: 5 Type: NAT Subtype: rpf-check Result: DROP Config: object network RC nat (any,mts-out) static interface service tcp 3000 8888 Additional Information: Result: input-interface: mts-out input-status: up input-line-status: up output-interface: inside output-status: up output-line-status: up Action: drop Drop-reason: (acl-drop) Flow is denied by configured rule
12-01-2019 07:49 AM
Catch it!!!
5 | Dec 01 2019 | 17:47:46 | 305013 | 178.127.181.1 | 8888 | 172.16.0.100 | 3000 | Asymmetric NAT rules matched for forward and reverse flows; Connection for tcp src mts-out:178.127.181.1/8888 dst inside:172.16.0.100/3000 denied due to NAT reverse path failure |
12-01-2019 08:25 AM - edited 12-01-2019 08:31 AM
I SWITCH
no ip routing
Int vlan 1
ip address 19216.0.2 255.255.255.0
Ip default-gateway 172.16.0.1
PC
static is address
12-01-2019 08:53 AM
Did it. Not helped.
interface Vlan1
no ip route-cache
ip default-gateway 172.16.0.1
12-01-2019 08:43 AM
I added a rule as recommended:
nat (any,any) after-auto source static any Local_Office_Network destination static Local_Office_Network Local_Office_Network no-proxy-arp
and visually everything is OK:
But I sltill get from my home PC:
I have no options left)
