11-29-2019 09:58 AM
Hello guys.
I have an strange problem wit ASA 5510 NAT settings.
We have one local network:
object network Local_Office_Network
subnet 172.16.0.0 255.255.248.0
description Local Network
and one ISP: 134.17.5.142
The main problem when I try to setup PAT to specific server inside the local network from outside:
object network RocketPAT
nat (inside,mts-out) static interface no-proxy-arp service tcp https 8443
It's not work, I always saw in Debug logging:
7 | Nov 29 2019 | 19:45:33 | 710005 | 178.127.193.130 | 56795 | 134.17.5.142 | 8443 | TCP request discarded from 178.127.193.130/56795 to mts-out:134.17.5.142/8443 |
I will give the main parts of the configuration below:
host 172.16.0.100
access-list Beltelecom_access_in extended permit tcp any object Rocket_Server eq https log debugging
nat (Wifi,mts-out) source dynamic any interface
nat (any,any) source static VPN VPN destination static Local_Office_Network Local_Office_Network
nat (CORP,inside) source static any any dns no-proxy-arp route-lookup
nat (inside,mts-out) source dynamic any interface
Could you tell me what is wrong. Thanks in advance!
Solved! Go to Solution.
12-01-2019 12:44 PM
Solved!
Deleted first rule NAT in section 1:
all old lists were cleared
clear configure access-list
and the correct NAT was configured for the network object:
object network server-rocket
access-list outside_acl extended permit tcp any object server-rocket eq 3000
nat (inside,mts-out) static interface service tcp 3000 3000
access-group outside_acl in interface mts-out
Many thanks to everyone who helped and participated!!!
Most likely, the reason was in the dump of old access lists, which ASA always sins ... It was necessary to delete everything initially).
11-29-2019 10:35 AM
try and use the simplified syntax below:
access-list Beltelecom_access_in extended permit tcp any object RocketPAT eq 443
access-list Beltelecom_access_in extended permit tcp any object RocketPAT eq 8443
host 172.16.0.100
nat (inside,mts-out) static interface service tcp 443 8443
11-29-2019 01:30 PM - edited 11-29-2019 01:44 PM
I did it, thanks but the same.
I have the impression that I have incorrect exclude the local traffic from NAT
nat (inside,mts-out) source dynamic Local_Office_Network interface
But without this, I do not have Internet access from the local network
11-29-2019 02:25 PM
which traffic (source/destination) do you want to send over the VPN ? Is the VPN actually working ?
11-30-2019 06:02 AM
Hello
As you have a any any in your NAT acl then that acl shouldn't be negating anything, your static nat config also looks applicable.
Can you post the results of the below please
show xlate | in 8443
packet-tracer input inside tcp 172.16.0.100 443 <--public ip> 8443
11-30-2019 06:41 AM
Hello.
Result of the command: "show xlate | in 8443"
TCP PAT from inside:172.16.0.100 443-443 to outside:134.17.5.142 8443-8443
UDP PAT from inside:172.16.0.254/48443 to outside:134.17.5.142/48443 flags ri idle 0:00:08 timeout 0:00:30
and next
Result of the command: "packet-tracer input inside tcp 172.16.0.100 443 134.17.5.142 8443"
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 134.17.5.142 255.255.255.255 identity
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (no-route) No route to host
11-30-2019 06:53 AM
the line 'ip address dhcp setroute' should in theory put a default route into your routing table. Does that default route show up when you do a 'show route' ?
11-30-2019 07:30 AM
Something like that:
S 172.16.0.0 255.255.248.0 [1/0] via 172.16.0.2, inside
C 172.16.0.0 255.255.255.0 is directly connected, inside
C 134.17.4.0 255.255.252.0 is directly connected, outside
S* 0.0.0.0 0.0.0.0 [1/0] via 134.17.4.1, outside
11-30-2019 06:56 AM
I cannot really figure out how your VPN is set up. For the sake of testing, just leave the two NAT lines in your config, and take the other ones out...
--> no nat (any,any) source static VPN VPN destination static Local_Office_Network Local_Office_Network
--> no nat (CORP,inside) source static any any dns no-proxy-arp route-lookup
11-30-2019 07:34 AM
Full picture:
Manual NAT Policies (Section 1)
1 (Wifi) to (outside) source dynamic any interface
translate_hits = 37, untranslate_hits = 0
Source - Origin: 0.0.0.0/0, Translated: 134.17.5.142/22
2 (any) to (inside) source dynamic VPN interface destination static Local_Office_Network Local_Office_Network
translate_hits = 547, untranslate_hits = 661
Source - Origin: 172.16.100.0/24, Translated: 172.16.0.1/24
Destination - Origin: 172.16.0.0/21, Translated: 172.16.0.0/21
3 (inside) to (outside) source dynamic Local_Office_Network interface
translate_hits = 58643, untranslate_hits = 22471
Source - Origin: 172.16.0.0/21, Translated: 134.17.5.142/22
Auto NAT Policies (Section 2)
1 (inside) to (outside) source static Rocket interface service tcp https 8443
translate_hits = 0, untranslate_hits = 0
Source - Origin: 172.16.0.100/32, Translated: 134.17.5.142/22
Service - Protocol: tcp Real: https Mapped: 8443
Manual NAT Policies (Section 3)
1 (inside) to (outside) source static obj-0.0.0.0 obj-0.0.0.0 destination static obj-0.0.0.0 obj-0.0.0.0 no-proxy-arp
Source - Origin: 0.0.0.0/32, Translated: 0.0.0.0/32
Destination - Origin: 0.0.0.0/32, Translated: 0.0.0.0/32
11-30-2019 08:31 AM
your CORP interface is shutdown, is that a typo ? Does your WEBVPN actually work ?
As far as I can tell, only the below NAT is needed.
object network VPN
subnet 172.16.100.0 255.255.255.0
nat (mts-out,mts-out) dynamic interface dns
nat (inside,mts-out) source static LOCAL_OFFICE_NETWORK LOCAL_OFFICE_NETWORK destination static VPN VPN
11-30-2019 08:41 AM
I applied your rules by deleting mine. Everything works fine regarding the local Internet and Wi-Fi.
But I still get "packet-tracer input inside tcp 172.16.0.100 443 134.17.5.142 8443"
Result:
input-status: up
output-status: up
Action: drop
11-30-2019 08:42 AM
This interface is really off.
Yes, I have AnyConnect configured and it really works from the outside.
11-30-2019 08:52 AM - edited 11-30-2019 08:53 AM
make the changes I suggested anyway, the webvpn should still work...
Obviously don't forget to add the static NAT entry, that's what it is all about...
11-30-2019 09:16 AM
Thanks, I checked - the VPN is working fine).
But the question is not about VPN).
I tried to transfer some services from the Internet to the internal LAN:
nat (inside,outside) static interface service tcp https 8085
This part is not work from my home, from outside.
I even changed the port from 8443 just in case. I want to get to the local office server by port and external address.
