Problem with PPPOE in 1800 router
adnane dakna
when I'm trying to configure my router 1801 with PPPOE  I have the message below
% PPPoE config from vpdn-group is converted to pppoe-profile based config.
% Continue PPPoE configuration under 'bba-group pppoe global'
My config is :
vpdn enable
vpdn-group PPPOE
accept-dialin
protocol pppoe
virtual-template 1
help me to understand this kind of message and to solve this problem.
best regards.
2 Accepted Solutions
Ivan Shirshin
Command syntax was changed with the code at some point and the message you are getting informs you that you should you a new set of commands, as PPoE configurations under vpdn-group were transitioned to bba-group.
Note that it does not simply deny your command but converts them automatically to new format and puts into configuration.
In overall, instead of:
    vpdn-group PPPOE
       accept-dialin
         virtual-template 1
         protocol pppoe
       pppoe limit per-... ...
you should use:
       virtual-template 1
       sessions per-... ...
and that will resolve your issue.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
welcome, Adhane. I would appreciate if you could mark the post if it was helpful and close the thread (mark correct answer :-) ).
Kind Regards,
Ivan
Ivan Shirshin
    vpdn-group PPPOE
       accept-dialin
         virtual-template 1
         protocol pppoe
you should use:
       virtual-template 1
Kind Regards,
Ivan
Kind Regards,
Ivan
Thanks Ivan , It's Ok for me now.
Kind Regards,
Ivan
