Problem with prefix list to filter networks on ospf.
Erico Verissimo
Hi there! Good Morning
I have a problem when I had applied the prefix-list on ospf. The network 10.206.2.0/27 don't enter on the rib.
follow the configuration:
Before prefix-list in:
#sh ip route 10.206.2.0
Routing entry for 10.206.2.0/27
  Known via "ospf 100", distance 110, metric 48952, type extern 1
  Last update from 192.168.162.77 on GigabitEthernet0/1, 14:13:02 ago
  Routing Descriptor Blocks:
  * 192.168.162.77, from 10.206.0.10, 14:13:02 ago, via GigabitEthernet0/1
      Route metric is 48952, traffic share count is 1
Prefix-list applied:
router ospf 100
 router-id 10.221.2.1
 log-adjacency-changes
 auto-cost reference-bandwidth 100000
 passive-interface GigabitEthernet0/0
 network 0.0.0.0 255.255.255.255 area 0
 distribute-list prefix filter_ospf in
ip prefix-list filter_ospf description Aplicacoes
ip prefix-list filter_ospf seq 10 permit 0.0.0.0/0
ip prefix-list filter_ospf seq 20 permit 10.98.0.0/28
ip prefix-list filter_ospf seq 30 permit 10.100.0.0/16
ip prefix-list filter_ospf seq 40 permit 10.206.0.0/16 le 24
ip prefix-list filter_ospf seq 50 permit 10.206.2.0/27
ip prefix-list filter_ospf seq 60 permit 10.208.0.0/16 le 24
ip prefix-list filter_ospf seq 70 permit 10.254.0.0/24 le 27
ip prefix-list filter_ospf seq 200 deny 0.0.0.0/0 le 32
After prefix-list in:
% Subnet not in table
All other prefixes are filtrated after putt the prefix-list on ospf, only network 10.206.2.0 don't appear in the sh ip route command.
Thank's and sorry about my english!! I'm learning it.
Hello.
Please check if you have the prefix in ospf rib - show ip ospf rib ...
and check if you have the prefix in LSDB - show ip ospf data ext ... + show ip ospf border
(you might have filtered out forwarding address)
Hello.
Vasilii,
Thank's for your answer. I did the test, apply the prefix again, and now I paid atention in the Forward Address, yes I just blocked this network. I put this network on permit like below:
#sh ip ospf database external 10.206.2.0
            OSPF Router with ID (10.221.2.1) (Process ID 100)
                Type-5 AS External Link States
  LS age: 329
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 10.206.2.0 (External Network Number )
  Advertising Router: 10.206.0.10
  LS Seq Number: 80004E19
  Checksum: 0xC5B7
  Length: 36
  Network Mask: /27
        Metric Type: 1 (Comparable directly to link state metric)
        MTID: 0
        Metric: 20
        Forward Address: 10.127.1.20
        External Route Tag: 0
ip prefix-list filter_ospf seq 25 permit 10.127.1.16/28
Now it works perfectly, thank's so much!!!
