Problem with redundant IPSEC VPN Setup ISR1100 to ISR4300
Pascal85045
Hi everyone,
I'm having a problem with my VPN Setup and the Routing.
I have Site A which consists of two Redundant Cisco ISR 4300 (v 17.03.05) Routers in Active / Standby Mode and i have Site B which consists of a Cisco ISR 1100 (v 16.12.04).
About the setup:
Site A:
The Cisco ISRs have two Interfaces with a Public Subnet. GigabitEthernet0/0/0.900 is the "outside" Subnet which is the transit Subnet to communicate with the Datacenter ISP for advertising our own Public Subnet via BGP which is on GigabitEthernet0/0/1 ("inside")
Active ISR 4300:
Interface GigabitEthernet0/0/0.900
description ISP BGP
encapsulation dot1Q 900
ip address 7.7.7.2 255.255.255.254
crypto map IKEv2
interface GigabitEthernet0/0/1
description TEST-FW1
ip address 3.3.3.4 255.255.255.0
standby version 2
standby 1 ip 3.3.3.3
standby 1 priority 110
standby 1 preempt delay minimum 60
standby 1 name HA-WAN
negotiation auto
Standby ISR 4300:
description ISP BGP
ip address 6.6.6.2 255.255.255.254
crypto map IKEv2
description TEST-FW2
ip address 3.3.3.5 255.255.255.0
standby version 2
negotiation auto
The IPSEC Profile and config for Site A looks identical on both:
crypto ikev2 proposal IKEv2
 encryption aes-cbc-256
 prf sha256 sha512
 integrity sha256
 group 14
crypto ikev2 policy 20
 proposal IKEv2
crypto ikev2 profile US1
 description US1 ISR VPN
 match identity remote any
 authentication remote pre-share key XXXXXXXXXXXXXXXXXXXXXXX
 authentication local pre-share key XXXXXXXXXXXXXXXXXXXXXX
crypto ipsec transform-set IKEv2 esp-aes 256 esp-sha256-hmac
 mode tunnel
crypto dynamic-map ISR-Dynamic 10
 set security-association lifetime seconds 86400
 set security-association replay window-size 128
 set transform-set IKEv2
 set ikev2-profile US1
 match address 105
 reverse-route
crypto map IKEv2 10 ipsec-isakmp dynamic ISR-Dynamic
The B-Side consists of one Cisco ISR 1100 which has a dynamic Public IP, it runs on either DSL or Cellular:
VPN Config:
crypto ikev2 proposal IKEv2_DH14
 prf sha256 sha512
 integrity sha256
 group 14
 proposal IKEv2_DH14
crypto ikev2 keyring US1-Key
 peer TEST-ISR1
  address 7.7.7.2
  pre-shared-key local XXXXXXXXXXXXXXXXXXX
  pre-shared-key remote XXXXXXXXXXXXXXXX
 peer TEST-ISR2
  address 6.6.6.2
  pre-shared-key local XXXXXXXXXXXXXXXXXXXXXXXXXX
  pre-shared-key remote XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
 description US1
 match identity remote address 7.7.7.2 255.255.255.255
 match identity remote address 6.6.6.2 255.255.255.255
 identity local key-id XXXXXXXXXXXXXXXXX
 keyring local US1-Key
 mode tunnel
crypto map outside_map 10 ipsec-isakmp
 set peer 7.7.7.2 default
 set peer 6.6.6.2
 match address 101
This the setup how we got it working. It looks like this:
So the VPN Tunnel on Site A terminates on the "outside" Transit Subnet to the ISP. But its performing really bad.
The B-Side is on private DSL Lines or cellular, so it drops from time to time, so its just a network dropout. What happens quite often is that the B-Side builds a tunnel to the default and the secondary peer when such an event happens.
And it stays connected to both Tunnels, this causes the traffic flow to stop.
I tried to create an EEM-Script for this which Tracks Internal Traffic (Ping)
 event manager applet RESET-VPN-US1_Track60
 event syslog pattern "%TRACK-6-STATE: 60 list boolean or Up -> Down"
 action 001 cli command "enable"
 action 002 cli command "clear crypto session remote 7.7.7.2"
 action 003 cli command "clear crypto session remote 6.6.6.2"
 action 099 syslog msg "US1 VPN tunnel cleared due to Track60 Recovery"
But still to many sites get stuck with two Tunnels and no traffic flow.
The optimal solution would be really easy: Attaching the cryptomap to the interface GigabitEthernet0/0/1 interface on the HSRP IP. That way we would not have to add two IPs in the cryptomap and could just connect to 3.3.3.3
So:
standby version 2
negotiation auto
crypto-map redundancy HA-WAN
Then it would look like this:
But this does not work. The Tunnel is established successfully and the B-Site has the route to the A-Side. But the A-Side can not return traffic as it will answer through the Interface GigabitEthernet0/0/0.900. Even though RRI is turned on.
We tried to solve this problem with Cisco TAC but they couldn't solve it and said its not supported. Unfortunately they could not provide a Solution.
What we have also tried as a workaround:
Added the "set security-association idletime 60" command. So after 60 seconds it will try to connect to the default peer. It works, after roughly 60-90 seconds its connected to the default peer, but it is still connected to the Standby-Peer and will stay there for multiple hours until the SA expires or another ISP drops kicks it. So again no traffic flow.
We have thought about using a FQDN for the both routers and then putting a Route53 HealthCheck to failover between them, but as the AWS healthcheckers can only check for TCP and change their public IP, we don't want to expose a responding Port to the Internet or constantly maintain ACLs.
OSPF or other routing protocols is not an option right now, we would have to add Interfaces for each Tunnel. We are talking 50+ devices so maintenance would be ugly even though we have Prime.
Could someone help me? I can't be the only one running such a setup, i can't believe there is no working setup for this.
Thank you very much
19 Replies 19
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/17826-ipsec-feat.html
I know this for IKEv1 but still same can use for IKEv2
check this solution do change if not work share the last config here.
--> The Cisco ISRs have two Interfaces with a Public Subnet. GigabitEthernet0/0/0.900 is the "outside" Subnet which is the transit Subnet to communicate with the Datacenter ISP for advertising our own Public Subnet via BGP which is on GigabitEthernet0/0/1 ("inside")
Post a diagram of your topology, as well as the full running configurations of all routers involved. If TAC cannot solve it, we probably have to lab this up.
Hi Georg,
Please find attached the Diagram. I will upload the configs in a moment.
And this is how i would like to have the setup:
Hi @Georg Pauwen
Unfortunately i can't post the running config, it has to much sensitive information, i have to cut out 80% of the config. I still think that my first post has all the relevant Config Lines listed.
The Question is, how can i get the VPN connection to GIG0/0/1 with correct traffic routing.
Establishing the VPN to the HSRP IP on GIG0/0/1 is not a problem, the Router just doesnt know how to answer / will try to answer through GIG0/0/0.900
Pascal
Hi, friend
I think about your issue,
in Site-B you will point to Site-A HSRP VIP this give you one IP "no default anymore"
Site-A you will config two HSRP
one face the OUT toward Site-B
other face the IN toward Site-A LAN
you must config and sure that the two HSRP elect same active to make return traffic always go through one router in Site-A.
Don't worry this topology for my notes if there is any modify I pleasure to know it.
Thanks for your reply, but i can not configure your proposed Solution.
Your suggestion is a HSRP IP on the outside interface towards Site B = Interface GigabitEthernet0/0/0.900
Both are different Transit Subnets provided by the Datacenter. They can not be in the same Subnet. So i can't put a HSRP on this.
Do you see topology there is Router in front of both HSRP peer.
other Solution is
statefull IPSec, this make both HSRP exchange IPSec tunnel info. and hence the Site-B connect to HSRP 1 or HSRP 2 no matter.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_vpnav/configuration/15-mt/sec-vpn-availability-15-mt-book/sec-state-fail-ipsec.html
I have checked the Document. Right now, we can't run Active / Active as its not allowed from the Contract, that could be changed.
The Problem with this topology is that the outside HSRP IPs of both Routers are in the same Network. This does not work as it would Destroy the redundancy as the Active and Standby Router would have to through the same Hop at the Datacenter. With the different Subnets and Hops, they use a different and separated Line in the DC.
sorry for my late reply. First of all, crypto maps are very much legacy. Can't you use VTIs, which would make routing (redundancy) a whole lot easier ?
--> The B-Side consists of one Cisco ISR 1100 which has a dynamic Public IP, it runs on either DSL or Cellular:
Do you have the B side config as well (as much as you can post) ? Is this is failover config (DSL primary/cell backup) ?
Hi @Georg Pauwen
I have sanitized the whole config. Please find it in the attachment. It is a Failover config GIG0/0/0 is primary and Cell 0/2/0 is failover.
But the failover is not source of the problem, as it will only trigger after a certain amount of seconds. When we have a short ISP drop of 5 seconds, the failover won't trigger but still give us the current issue.
For your other comment:
I do not see VTI as option yet. The Problem is that we have 50+ Devices on the "B-Side". Connect to two Locations, with the redundant ISR Pair. So we are talking 200+ VTI Tunnels / Networks. That will be ugly to manage and maintain.
can you post a similar sanitized config for both Site A routers as well ? I am trying to lab this up, it will take a few hours as it is, a somewhat comprehensive text file would speed things up.
Hi @Georg Pauwen
I have prepared the sanitized config, I had to cut out some stuff as we have a lot of VTI Tunnels, I removed the unnecessary.
Thanks a lot
Pascal
