Problem with serial interfaces
John Blakley
All,
We have 6 T1s that are bundled in MLP. I noticed that we have CRCs on ALL of the serial interfaces, and I'm not sure why. Below is the result of "sh int | inc CRC".
14 input errors, 14 CRC, 10 frame, 6 overrun, 0 ignored, 7 abort
10 input errors, 10 CRC, 8 frame, 6 overrun, 0 ignored, 5 abort
30 input errors, 30 CRC, 22 frame, 17 overrun, 0 ignored, 8 abort
31 input errors, 31 CRC, 25 frame, 19 overrun, 0 ignored, 12 abort
28 input errors, 28 CRC, 25 frame, 20 overrun, 0 ignored, 14 abort
26 input errors, 26 CRC, 21 frame, 18 overrun, 0 ignored, 8 abort
What could cause this? CRCs are normally a physical problem (duplexing, bad cable, etc.), but I can't see all 6 circuits having an issue.
John
HTH, John *** Please rate all useful posts ***
5 Replies 5
paolo bevilacqua
You have to compare against the packets received counter. If it 1000 is one thing, if it is 1,000,000 it's another.
Beside that, look at "show controllers T1" also.
The provider has run tests and they said that it's running clean to the csu. The only thing that I recently changed was the IOS, so I downgraded back to the original IOS last night and the problem remains. I still have a ton of CRC errors on all my interfaces.
Serial0/0/0:0 is up, line protocol is up
90 input errors, 90 CRC, 69 frame, 58 overrun, 0 ignored, 47 abort
Serial0/0/1:0 is up, line protocol is up
52 input errors, 52 CRC, 36 frame, 34 overrun, 0 ignored, 19 abort
Serial0/1/0:0 is up, line protocol is up
187 input errors, 187 CRC, 134 frame, 104 overrun, 0 ignored, 80 abort
Serial0/1/1:0 is up, line protocol is up
24 input errors, 24 CRC, 18 frame, 15 overrun, 0 ignored, 12 abort
Serial0/2/0:0 is up, line protocol is up
174 input errors, 174 CRC, 126 frame, 106 overrun, 0 ignored, 75 abort
Serial0/2/1:0 is up, line protocol is up
114 input errors, 114 CRC, 85 frame, 67 overrun, 0 ignored, 57 abort
They're all on my T1 WICs. "sh controlller t1" shows this:
Total Data (last 42 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
1044 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1044 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 12 Unavail Secs
All of the interfaces have the errored secs in the same general range.
Is there anything I should be looking for at my end?
John
Oh, and this is MLFR. All of my interfaces are configured like:
interface Serial0/0/0:0
no ip address
encapsulation frame-relay MFR0
no arp frame-relay
frame-relay multilink lid link1
with the frame-relay line multilink lid linkx changing for each interface: link2, link3, link4, link5, and link6.
John
John:
Those Slip seconds caught my eye.
Have you checked how the timing is configured for each circuit and the bundle as well?
Typically, the router interfaces should be set for line timing.
Victor
Victor,
We had to clear counters on this since we changed a couple of things, but it didn't help. My clock source is line:
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20040802, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (511 seconds elapsed):
14 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
14 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Here are the configuration for the controllers, multilink, and serial:
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface MFR0
no ip address
load-interval 30
frame-relay multilink bid DataCenter
frame-relay lmi-type ansi
interface MFR0.790 point-to-point
ip address
no cdp enable
frame-relay interface-dlci 790 IETF
no ip address
no arp frame-relay
John
