Problem with Serial interfaces
peguayapero
AT PRESENT I have a router that is connected to other two sites by different ISP.
I observe many drops in the linea "Input queue" :
In the other two routers does not present these drops.
That may be occurring?
peguayapero
I forgot attachments
Your problem appears to be output drops, not input drops. Output drops are a result of your traffic exceeding the capacity of your link and from what I can see, you are driving the interfaces to capacity.
The only solution to your problem is to add more bandwidth.
Hope that helps - pls rate the post if it does.
Paresh
