Policy based routing to different ISP's
kbehymerisg
I want to know if it's possible to route different internal subnets out different interfaces to the Internet. BGP is not an option.
Here is my topology:
ISP 1 ISP 2
Router
Subnet 1 Subnet 2
The basic question is: can I route all internet traffic from subnet 1 to ISP 1 and subnet 2 to ISP 2?
pkhatri
Level 11
Level 11
HI,
Are your subnet1 and subnet2 public IPs or do you need to use NAT ?
Paresh
The subnet 1 and 2 are going to use NAT.
vladrac-ccna
Level 5
Level 5
I think the subject of this conversating resolves the problem.
You can configure your route to do policy routing, or route based on source, or better yet use an extended ACL to define traffic going to www and point it to next-hop that you see fit.
check the following example:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hirp_c/ch20/piconfig.htm#wp1002348
in your case you should use an extedend acl like
access-list 100 permit 10.0.0.0 0.0.0.255 any eq www
something along those lines.
Hope this help!
Vlad
Here's a sample config that will do what you want:
interface Serial0
ip address 255.255.255.252
ip nat outside
interface Serial1
ip nat outside
interface GigabitEthernet0/0
ip address 10.1.1.1 255.255.255.0
ip policy route-map PBR
ip nat inside
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Serial1
ip nat inside source route-map ISP1-map interface serial0
ip nat inside source route-map ISP2-map interface Serial1
route-map ISP11-map permit 10
match ip address 1
route-map ISP12-map permit 10
match ip address 2
route-map PBR permit 10
match ip address 1
set interface serial0
route-map PBR permit 20
match ip address 2
set interface serial1
access-list 1 permit
access-list 2 permit
Hope that helps - pls rate the post if it does.
Paresh
