05-21-2008 10:17 AM - edited 03-03-2019 10:02 PM
I have Catalyst 6509 with 2 supervisor 720, one is Active and the other one is not presented to the switch. When I show the modules I get that the second supervisor is unknown and Not Applicable(See the file attached).
the second supervisor is booted on rommon.
I verify the version of the firmware and IOS (12.2(33)SXH), I have the same versions on the both supervisors.
Can you help please to resolve this issue.
Thanks.
05-21-2008 11:10 AM
If the second supervisor is a rommon, is an indication that is unable to load the IOS.
Verify both Supervisors have the same memory and flash requirement.
Can you post the output from typing show redundancy and show boot
__
Edison.
05-21-2008 02:55 PM
05-21-2008 03:39 PM
Can you verify where the file is stored in the secondary supervisor ?
On the primary supervisor the file is stored in bootflash:
Per your attached output:
bootflash:s72033-ipservicesk9_wan-mz.122-33.SXH.bin,1;
Once you find where exactly is the file, do a manual boot from the secondary supervisor via the console connection.
05-21-2008 11:55 PM
I have started manually the secondary supervisor, I get this message from console :
00:00:20: %PFREDUN-6-STANDBY: Initializing as STANDBY processor for this switch
00:00:21: %SYS-SPSTBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:20: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:21: %OIR-SPSTBY-6-CONSOLE: Changing console ownership to route processor
After that the console of the secondary supervisor is blocked.
But when I set the Show Module on the first supervisor I still get the unknown and Not Applicable (See Attached).
05-22-2008 02:57 AM
You'll find in the attached file the output of starting up the secondary supervisor.
The software is reloaded due to a crash on start up (See attached file).
Also I get these messages:
00:00:25: %ICC-4-COMM: Communication failure occurred while open port on card 6 (7-no such port)
-Traceback= 40A4ACEC 40A4C0E8 40A4C484 40A4C728 40D002B8 40D00374 40CFED10 41B9D594 41B9D580
00:00:25: %RPC-2-FAILED: Failed to send RPC request for registration message (fatal)
-Traceback= 40D002D4 40D00374 40CFED10 41B9D594 41B9D580
05-22-2008 05:24 AM
Tracebacks are always bad news.
Try re-seating the module and manual booting once again.
If that fails, I recommend opening a TAC case. It looks like you have a faulty Sup.
Good luck
__
Edison.
