Problem with traffic shaping a 3750 metro
jimmcgrady
I'm supporting several 3750 metro switches comprising a WAN.  The presentation speed of each multipoint layer2 interface throughout the WAN is being increased, so ive been asked to apply some shaping to limit egress speed dependent on the destination IP of the traffic. Advice ive been given is that the following example suits what i need:
ip access-list extended foo_acl
permit ip any 192.168.10.0 0.0.0.255
class-map match-any foo_class
match access-group foo_acl
policy-map foo_policy
class foo_class
shape average 10000000
int gig1/1/1
service-policy output foo_policy
Ive applied this. All goes in fine until i apply the service-policy to the ES interface. At that point, i get the errors:
QoS: Invalid match access-group in class foo_class
QoS: Invalid policy map foo_policy
Any idea what i'm doing wrong?
nkarpysh
Hi Jim,
Not sure about your IOS but I think this should be relevant.
From this page:
http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_37_se/configuration/guide/swqos.html#wp1281296
Class maps that contain ACLs are not supported in either an egress policy or in a hierarchical ingress policy attached to an ES port or EtherChannel. You cannot configure the match access-group acl-index-or-name class-map configuration command in a hierarchical policy map.
You can try matching the traffic based on vlans and shape it accordingly.
Here is the link which explains regarding "Configuring Shaping":
http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_37_se/configuration/guide/swqos.html#wp1282429
Here is the example from the link:
This example shows how to configure VLAN-level, average-rate shaping. It
limits each traffic class, vlan101 and vlan102, to a data transmission
rate of 400 Mbps.
Switch(config)# class-map match-all vlan101
Switch(config-cmap)# match vlan 101
Switch(config-cmap)# exit
Switch(config)# class-map match-all vlan102
Switch(config-cmap)# match vlan 102
Switch(config)# policy-map vlan-policy
Switch(config-pmap)# class vlan101
Switch(config-pmap-c)# shape average 400000000
Switch(config-pmap-c)# exit
Switch(config-pmap)# class vlan102
Switch(config-pmap)# exit
Switch(config)# interface gigabitethernet1/1/1
Switch(config-if)# switchport trunk encapsulation dot1q
Switch(config-if)# switchport mode trunk
Switch(config-if)# service-policy output vlan-policy
Hope this helps,
Nik
HTH,
Niko
