Problems applying security k9
CiscoMedMed
After applying my PAK on license/go - I received a file to apply to my CIsco 1100 ISR. The file ends in a .lic.
But when I look at instructions on applying the license the command references a file ending .xml. (see URL)
I don't see anywhere that says "rename your lic to xml". Anyhow - frustrating that there's not a simplier
way to activate this feature. Have wasted time. Can someone advise on how I can get the license activated?
Also do I need to be concerned with Smart Licensing? I just want to be able to have "crypto map" etc
work on my ISR.
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#36562
Router#copy tftp: bootflash:
Address or name of remote host [10.59.50.21]?
Source filename [FGL296961VG_20200212040207.lic]? FGL2327276W_20200214105125895.lic
Destination filename [FGL2327276W_20200214105125895.lic]?
Accessing tftp://10.59.50.21/FGL2327276W_20200214105125895.lic...
Loading FGL2327276W_20200214105125895.lic from 10.59.50.21 (via Vlan50): !
[OK - 1192 bytes]
1192 bytes copied in 0.032 secs (37250 bytes/sec)
Router#license install bootflash:FGL2327276W_20200214105125895.lic
Installing licenses from "bootflash:FGL2327276W_20200214105125895.lic"
% Error: License installation failed with error: XML parsing failed
Leo Laohoo
Post the complete output to the command "sh license udi" and "sh inventory" (first page only).
Router#sh license udi
SlotID PID SN UDI
* C1111-8P FGL2334216W C1111-8P:FGL2334216W
Router#sh inventory
INFO: Please use "show license UDI" to get serial number for licensing.
NAME: "Chassis", DESCR: "Cisco C1111-8P Chassis"
PID: C1111-8P , VID: V01 , SN: FGL2334216W
NAME: "Power Supply Module 0", DESCR: "External Power Supply Module"
PID: PWR-12V , VID: V01 , SN: JAB0929092D
NAME: "module 0", DESCR: "Cisco C1111-8P Built-In NIM controller"
PID: C1111-8P , VID: , SN:
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 port Gigabitethernet Module"
PID: C1111-2x1GE , VID: V01 , SN:
NAME: "NIM subslot 0/1", DESCR: "C1111-ES-8"
PID: C1111-ES-8 , VID: V01 , SN:
NAME: "module R0", DESCR: "Cisco C1111-8P Route Processor"
PID: C1111-8P , VID: V01 , SN: FOC233324ZG
License file is for an appliance with the serial number of "FGL2327276W".
Serial number of the unit is "FGL2334216W".
They DO NOT MATCH.
Oh - I had anonymized the serial number in the original post. But in replying to your question I realized the serial doesn't reveal much.
Is the command I'm entering correct? I can't find a manual that mentions the .lic file - only .xml. TY
