MPLS TE Tunnel not coming UP with explicit Path
Sunil_06
hi Team,
i am trying to setup a TE tunnel from ACC3 to AGG1 but it is not comming up. i have configured exlicit path and using the same in tunnel interface but it is not working. i tried to remove the explicit path and configured dynamic after that tunnel came up. can anyone please help me to share the reason why tunnel is not coming up after configuring explicit path
ACC3#show run int tunnel 0
Building configuration...
Current configuration : 318 bytes
interface Tunnel0
description to_agg1
ip unnumbered Loopback0
mpls traffic-eng tunnels
tunnel mode mpls traffic-eng
tunnel destination 1.1.1.1
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng path-option 1 explicit name to_agg1
tunnel mpls traffic-eng record-route
no routing dynamic
end
ACC3#
ACC3#show ip explicit-paths
PATH to_agg1 (strict source route, path complete, generation 12)
1: next-address 192.168.13.1
ACC3#
ACC3#show mpls traffic-eng tunnels t0
Name: to_agg1 (Tunnel0) Destination: 1.1.1.1
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, type explicit to_agg1
Config Parameters:
Bandwidth: 0 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF
Metric Type: TE (default)
AutoRoute: enabled LockDown: disabled Loadshare: 0 bw-based
auto-bw: disabled
Shortest Unconstrained Path Info:
Path Weight: 2000 (TE)
Explicit Route: 192.168.13.1 192.168.11.1 1.1.1.1
History:
Tunnel:
Time since created: 1 hours, 22 minutes
Time since path change: 27 minutes, 18 seconds
Number of LSP IDs (Tun_Instances) used: 339
Prior LSP:
ID: path option 2 [237]
Removal Trigger: configuration changed
Path Option 1:
Last Error: PCALC:: No addresses to connect 192.168.13.1 to 1.1.1.1
ACC3#
ACC3#
*Feb 15 19:12:56.340: TE-PCALC: Tunnel0 Path Setup [1111.1111.1111.00] 1.1.1.1: FULL_PATH (isis level-2)
*Feb 15 19:12:56.340: TE-PCALC: bw 0, min_bw 0, metric: 0
*Feb 15 19:12:56.340: TE-PCALC: setup_pri 7, hold_pri 7
*Feb 15 19:12:56.340: TE-PCALC: affinity_bits 0x0, affinity_mask 0xFFFF
*Feb 15 19:12:56.340: TE-PCALC path type unidirectional
*Feb 15 19:12:56.340: TE-PCALC endpoint switching capability psc1, link encoding packet
*Feb 15 19:12:56.340: TE-PCALC transit switching capability psc1, link encoding packet
ACC3#
*Feb 15 19:12:56.340: TE-PCALC_PATH: create_path_hoplist: No addresses to connect 192.168.13.1 to 1.1.1.1
ACC3#show mpls traffic-eng topology
My_System_id: 3333.3333.3333.00 (isis level-2)
Signalling error holddown: 10 sec Global Link Generation 8
IGP Id: 0111.1111.1111.00, MPLS TE Id:11.11.11.11 Router Node (isis level-2)
link[0]: Point-to-Point, Nbr IGP Id: 3333.3333.3333.00, nbr_node_id:8, gen:6
frag_id 0, Intf Address:192.168.13.1, Nbr Intf Address:192.168.13.2
TE metric:1000, IGP metric:1000, attribute flags:0x0
SRLGs: None
physical_bw: 10000 (kbps), max_reservable_bw_global: 7500 (kbps)
max_reservable_bw_sub: 0 (kbps)
Global Pool Sub Pool
Total Allocated Reservable Reservable
BW (kbps) BW (kbps) BW (kbps)
bw[0]: 0 7500 0
bw[1]: 0 7500 0
bw[2]: 0 7500 0
bw[3]: 0 7500 0
bw[4]: 0 7500 0
bw[5]: 0 7500 0
bw[6]: 0 7500 0
bw[7]: 0 7500 0
link[1]: Point-to-Point, Nbr IGP Id: 1111.1111.1111.00, nbr_node_id:11, gen:6
frag_id 0, Intf Address:192.168.11.2, Nbr Intf Address:192.168.11.1
SRLGs: None
physical_bw: 10000 (kbps), max_reservable_bw_global: 0 (kbps)
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
IGP Id: 0222.2222.2222.00, MPLS TE Id:22.22.22.22 Router Node (isis level-2)
link[0]: Point-to-Point, Nbr IGP Id: 3333.3333.3333.00, nbr_node_id:8, gen:5
frag_id 0, Intf Address:192.168.23.1, Nbr Intf Address:192.168.23.2
SRLGs: None
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
link[1]: Point-to-Point, Nbr IGP Id: 2222.2222.2222.00, nbr_node_id:10, gen:5
frag_id 0, Intf Address:192.168.22.2, Nbr Intf Address:192.168.22.1
SRLGs: None
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
IGP Id: 1111.1111.1111.00, MPLS TE Id:1.1.1.1 Router Node (isis level-2)
link[0]: Point-to-Point, Nbr IGP Id: 0111.1111.1111.00, nbr_node_id:9, gen:8
frag_id 0, Intf Address:192.168.11.1, Nbr Intf Address:192.168.11.2
SRLGs: None
bw[0]: 0 7500 0
bw[1]: 0 7500 0
bw[2]: 0 7500 0
bw[3]: 0 7500 0
bw[4]: 0 7500 0
bw[5]: 0 7500 0
bw[6]: 0 7500 0
bw[7]: 0 7500 0
link[1]: Point-to-Point, Nbr IGP Id: 2222.2222.2222.00, nbr_node_id:10, gen:8
frag_id 0, Intf Address:192.168.21.1, Nbr Intf Address:192.168.21.2
TE metric:5000, IGP metric:5000, attribute flags:0x0
SRLGs: None
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
IGP Id: 2222.2222.2222.00, MPLS TE Id:2.2.2.2 Router Node (isis level-2)
link[0]: Point-to-Point, Nbr IGP Id: 0222.2222.2222.00, nbr_node_id:12, gen:7
frag_id 0, Intf Address:192.168.22.1, Nbr Intf Address:192.168.22.2
SRLGs: None
bw[0]: 0 7500 0
bw[1]: 0 7500 0
bw[2]: 0 7500 0
bw[3]: 0 7500 0
bw[4]: 0 7500 0
bw[5]: 0 7500 0
bw[6]: 0 7500 0
bw[7]: 0 7500 0
link[1]: Point-to-Point, Nbr IGP Id: 1111.1111.1111.00, nbr_node_id:11, gen:7
frag_id 0, Intf Address:192.168.21.2, Nbr Intf Address:192.168.21.1
SRLGs: None
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
IGP Id: 3333.3333.3333.00, MPLS TE Id:3.3.3.3 Router Node (isis level-2)
link[0]: Point-to-Point, Nbr IGP Id: 0222.2222.2222.00, nbr_node_id:12, gen:1
frag_id 0, Intf Address:192.168.23.2, Nbr Intf Address:192.168.23.1
SRLGs: None
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
link[1]: Point-to-Point, Nbr IGP Id: 0111.1111.1111.00, nbr_node_id:9, gen:1
frag_id 0, Intf Address:192.168.13.2, Nbr Intf Address:192.168.13.1
SRLGs: None
bw[0]: 0 0 0
bw[1]: 0 0 0
bw[2]: 0 0 0
bw[3]: 0 0 0
bw[4]: 0 0 0
bw[5]: 0 0 0
bw[6]: 0 0 0
bw[7]: 0 0 0
ACC3#
0 Replies 0
