Problems connecting routers
cisconoobie
Level 7
Level 7
I dont know if I'm just retarted or soemthing but I cannot get these 2 routers to connect.
I have two Cisco 2621XM router both equipped with NM-4A/S cards.
I connect router1 with a 1 foot dte/dce cable on serial 1/1 DTE side and the other on serial 1/2 DCE side.
Router1
int serial 1/1
ip address 155.1.0.1 255.255.255.252
encapsulation hdlc
Router2
int serial 1/2
ip address 155.1.0.2 255.255.255.252
clock rate 64000
encapsulation hdlc
Am I missing something?
I shutdown and unshut and the interface on router1 goes up and down after like 15 seconds. and I cant ping for the life of me.
Any advise?
5 Replies 5
Edison Ortiz
The up/down is an indication that clocking is not configured in the link.
I see you have the clock-rate command at one side, which should be the DCE side. Can we verify that is indeed the DCE side by posting show interface controllers from both routers?
__
Edison.
I changed routers and same problem
Router2 - DTE Side of cable
interface Serial1/1
R2#show controllers serial 1/1
CD2430 Slot 1, Port 1, Controller 0, Channel 1, Revision 19
Channel mode is synchronous serial
idb 0x84D45D08, buffer size 1524, V.35 DTE cable
Global registers
rpilr 0x2, rir 0x0, risr 0x0, rfoc 0x0, rdr 0x0
tpilr 0x1, tir 0x0, tisr 0x0, tftc 0x0, tdr 0x2
mpilr 0x3, mir 0x0, misr 0x0
bercnt 0xFF, stk 0x0
Per-channel registers for channel 1
Option registers
0x02 0x00 0x42 0xE7 0xE0 0x00 0x00
Command and status registers
cmr 0xC0, ccr 0x00, csr 0xC8, msvr-rts 0x11, msvr-dtr 0x11
Clock option registers
rcor 0x86, rbpr 0x01, tcor 0xC8, tbpr 0x01
Interrupt registers
ier 0x89, livr 0x04, licr 0x04
DMA buffer status 0x00
DMA receive registers
arbaddr 0x79C5024, arbcnt 1548, arbsts 0x1
brbaddr 0x79C56A4, brbcnt 1548, brbsts 0x1
rcbaddr 0x0
DMA transmit registers
atbaddr 0x0, atbcnt 0, atbsts 0x0
btbaddr 0x0, btbcnt 0, btbsts 0x0
tcbaddr 0x0
Special character registers
schr1 0x00, schr2 0x00, schr3 0x00, schr4 0x00
scrl 0x0, scrh 0x0, lnxt 0x11
Driver context information
Context structure 0x88141870, Register table 0x40800400
Serial Interface Control 5:1 Register (0x40800806) is 0x0
Adaptor Flags 0x0
Serial Modem Control Register (0x40800808) is 0x18
Receive static buffer 0x880DDFFC
Receive particle buffers 0x84D47880, 0x84D478C0
Transmit DMA buffers 0x0, 0x0, 0x0, 0x0
Transmit packet with particles 0x0, first word is 0x0
Interrupt rates (per second) transmit 0, receive 0, modem 0
True fast-switched packets 0
Semi fast-switched packets 0
Transmitter hang count 0
Residual indication count 0
Bus error count 0
Aborted short frames count 0
CRC short frames count 0
Tx DMA low threshold count 0
Error counters
CTS deassertion failures 0
Nested interrupt errors transmit 0, receive 0, modem 0
R2#show int serial 1/1
Serial1/1 is down, line protocol is down
Hardware is CD2430 in sync mode
Internet address is 155.1.0.1/30
MTU 1500 bytes, BW 128 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/32 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 96 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 40 interface resets
0 unknown protocol drops
0 carrier transitions
DCD=down DSR=down DTR=up RTS=up CTS=down
Router3 - DCE Side
interface Serial1/3
clock rate 64000
R3#show controllers serial 1/3
CD2430 Slot 1, Port 3, Controller 0, Channel 3, Revision 19
idb 0x84FEF208, buffer size 1524, V.35 DCE cable, clockrate 64000
Global registers
Per-channel registers for channel 3
Option registers
0x02 0x00 0x42 0x67 0x60 0x00 0x00
rcor 0x86, rbpr 0x01, tcor 0xC0, tbpr 0x11
Interrupt registers
ier 0x89, livr 0x0C, licr 0x0C
arbaddr 0x79CF324, arbcnt 1548, arbsts 0x1
brbaddr 0x79CECA4, brbcnt 1548, brbsts 0x1
rcbaddr 0x0
tcbaddr 0x0
Context structure 0x88144E64, Register table 0x40800400
Serial Interface Control 5:1 Register (0x4080080E) is 0x80
Adaptor Flags 0x0
Serial Modem Control Register (0x40800810) is 0x1D
Receive static buffer 0x84F739BC
Receive particle buffers 0x84FF0DC0, 0x84FF0D80
Bus error count 0
Error counters
R3#show int serial 1/3
Serial1/3 is down, line protocol is down
Internet address is 155.1.0.2/30
0 output errors, 0 collisions, 49 interface resets
DCD=up DSR=up DTR=down RTS=down CTS=up
Now the connection does not come up at all. I cant get it to go up or down.
Any advise?
Ok figured it out. BAD Serial card!!
What a waste of time.
Thanks for posting the resolution of your problem, it makes the forum more useful.
Rated accordingly.
__
Edison.
