problems regarding pppoe on 2600
gleeb1234
i am trying to configure ppoe on my 2600 router and i am expiriencing some problems.
first of all i'll post the version of my router so if theres a problem on my IOS let me know and i'll upgare it.
IOS (tm) C2600 Software (C2600-I-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 07-Dec-99 02:12 by phanguye
Image text-base: 0x80008088, data-base: 0x807AAF70
i am watching the configuration from a webpage i have found:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080126dc0.shtml
now i am unable to activate some things i am seeing there like.
vpdn-group
i would assume its cisco(config)#>vpdn-group
but even with i prompt the "?" on the vpdn i get nothing.
secound is enabling the pppoe on the eth int. same as with the vpdn, seems like i dont have the command to do it.
what am i doing wrong... can anyone guid me threw it in more details... do i need to upgrade my IOS?
nethelper
Level 3
Level 3
your IOS version is IP Only, and indeed not sufficient for PPPoE. You need e.g. 12.2(15)T17
(image name c2600-is-mz.12.2-15.T17), but that version requires 64MB DRAM and 32MB Flash. A ´show version´ will tell you how much DRAM and Flash you have...
Nethelper
nethelper
Level 3
Level 3
Nethelper
