DHCP reservation
ladan.eftetahi
hello
could you pls tell me how can I create a DHCP reservation on 3750 or any other switches?
pkhatri
Level 11
Level 11
Hi Ladan,
Here's a sample config of how to set up the 3750(or other IOS-based switch) as a DHCP server:
service dhcp
ip dhcp pool DCHPPool1
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server
ip dhcp excluded-address 10.1.1.1
(since you don't want it handing out addresses such as the router's address)
You can change the addresses to suit your needs.
Hope that helps - pls rate the post if it does.
Paresh
just in case you are looking for a MAC-to-IP address reservation, below is what the configuration would look like (IP and MAC addresses used are arbitrary). Watch out: Windows clients require the ´client-identifier´ option instead of the hardware-address. There is a difference between e.g. Linux clients and Windows clients: Linux clients will use just the MAC address without the client-id, while
Windows clients use the client-id in the DHCP request, which consists of the MAC-address prepended by a ´01´
Also keep in mind that for each client, you would need another dhcp pool.
ip dhcp pool reservation1
host 192.168.1.2 mask 255.255.255.0
hardware-address 08c5.d4500.0311
or
client-identifier 0108.c5d4.0003.11
client-name Computer1
default-router 192.168.1.1
domain-name yourdomain.com
dns-server 172.16.1.1
netbios-name-server 172.16.1.2
netbios-node-type h-node
Nethelper
