Problems with a School project
TS40
Hey, i am student. And for a school project we have to make a network for a company. I don't really now how to start this project. Case study The newly purchased building consists of a reception department and an administration department + management.
After consultation with management, the IT architect designed the following design. After a few minor adjustments, our technical department installed the hardware devices below. These now need to be fully configured. Firt Floor: Wired lan: 192.229.x.x/16 Wireless Lan Controller: on this device we create 3 Vlans for the networks below.
802.11 visitors 192.220.x.x/24
802.11 employees 192.220.x.x/24
802.11 management 192.220.x.x/28
Printer First Floor has a fixed IP Private AP 192.168.0.0/30 SSID should NOT be visible. Reception: Wired lan: 172.77.x.x//16 Wireless Lan Controller: on this device we create 4 Vlans for the networks below.
802.11 visitors 172.68.x.x/24
802.11 employees 172.68.x.x/24
802.11 management 172.68.x.x/28
802.11 Sales 172.68.x.x/28
Printer reception has a fixed IP The 2 department routers use EIGRP and are connected to the ISP via default route All PCs and laptops use DHCP. I have already configured a few things
such as dhcp. I put my packet tracer in the attachment.
thank you in advance
Ruben Cocheno
@TS40
This is a good start and it will help you to learn the foundations. what are the problems that you need help with?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
We just got dhcp up and running. But we are stuck at the wired part. we are not sure how to do VLSM with this case. If you could help us with that that would already do a lot.
