Problems with AWS Transit CSR, BGP and advertised routes
andrew.rogers
I started off by contacting aws support, and they gave up and told me to ask here
The idea of the AWS transit network is that it uses BGP to negotiate the interconnectivity of subnets between worldwide regions, as there is no direct way of doing so within aws
We are trying to route traffic from 172.30.0.0/16 via the transit network, and onwards to others.
TCPDump shows packets leaving this network, arriving on the destination network, and the reply being sent back.  However this reply never reaches there
Some digging around on the cisco CSR showed something rather strange when looking at the bgp info
 Route Distinguisher: nnnnn:3 (default for vrf vpn-12345678)
*> x.x.x.x/16 y.y.y.y 0 9059 i *> x.x.x.x/16 y.y.y.y 0 32768 ? *> x.x.x.x/22 y.y.y.y 200 0 9059 i *> x.x.x.x/24 y.y.y.y 200 0 9059 i *> x.x.x.x/24 y.y.y.y 100 0 9059 i *> x.x.x.x/24 y.y.y.y 200 0 9059 i * 172.30.0.0 169.254.45.17 200 0 7224 i *> y.y.y.y 100 0 7224 i *> x.x.x.x/22 y.y.y.y 100 0 9059 i * x.x.x.x y.y.y.y 100 0 7224 i * y.y.y.y 100 0 9059 i * y.y.y.y 100 0 9059 i * y.y.y.y 200 0 7224 i *> y.y.y.y 100 0 7224 i
I've blanked out a lot of the other details, but left the subnet masks in
My support contact at aws assured me that the vpn tunnel was sending its local network correctly, so it must be something on the cisco side of it.  He recommended setting up a route map to filter out 172.30.0.0, but this does not seem to then allow 172.30.0.0/16
Has anyone got experience with manually manipulating BGP lists, or suggestions on a work around?
11 Replies 11
so you are receiving the 172.30.0.0 from a Windows APIPA address (169.254.x.x)...weird indeed. Can you post the config of the CSR, and a 'show version' ?
it looks like AWS is using the 169.254 for their BGP VPN peers, so the address would make sense.
The config of the CSR would be useful.
Also, are you using the AWS VPC Wizard, and do you have route propagation enabled as described in the attached document:
http://docs.aws.amazon.com/AmazonVPC/latest/UserGuide/VPC_VPN.html
Route propagation is enabled.
AWS configures its tunnels to use 169.x.x.x addresses as the internal end points for the vpns, so the tunnel config looks like this:
interface Tunnel1
ip vrf forwarding vpn-1234567
ip address 169.254.45.18 255.255.255.252
ip tcp adjust-mss 1387
tunnel source GigabitEthernet1
tunnel mode ipsec ipv4
tunnel destination 1.2.3.4
tunnel protection ipsec profile ipsec-vpn-aws
ip virtual-reassembly
and the bgp config:
router bgp 54321
bgp log-neighbor-changes
address-family ipv4 vrf vpn-1234567
neighbor 169.254.45.17 remote-as 7224
neighbor 169.254.45.17 timers 10 30 30
neighbor 169.254.45.17 activate
neighbor 169.254.45.17 as-override
neighbor 169.254.45.17 soft-reconfiguration inbound
exit-address-family
I did try assigning the network 172.30.0.0 to that bgp vrf router like this:
router bgp 54321
network 172.30.0.0 mask 255.255.0.0
But when I did a show run, it just said
network 172.30.0.0
Is it possible the show commands giving misleading information?
looking at the docs from AWS, in their configuration example, they don't use a VRF. Is it possible to reconfigure and follow the guidelines as explained in the attached doc ?
http://docs.aws.amazon.com/AmazonVPC/latest/NetworkAdminGuide/Cisco.html#CustomerGatewayDetail1
Using VRF is as the AWS solution causes it to be deployed. It uses various AWS technologies to detect Virtual Private Clouds that require a vpn connection.  It then creates a vpn from that location to the Cisco device, parses config file and logs into the cisco devices to apply config autonomously. In theory I should never need to log into the box!
Hello Andrew,
makes sense. Strange though that their own docs give config examples without VRFs...
I'll look and check further...
I'm still none the wiser to why the cisco device is showing 172.30.0.0/16 without the network mask, but I've found the cause of my routing problems
On most of my AWS route tables, I'd got the VPN gateway set to propagate the route it had going from it.  On one of the tables for the destination network, this had got un-set, and not all the required manual entries had been put in.  After correcting this, traffic started flowing as expected
Thanks for all the suggestions
Hello
You trying to re-advertise this /16 that originated ASN9059 to ebgp neigbour 169.254.45.17 ASN7224 as a connected route.
However it looks like ebgp neighbor 169.254.45.17 ASN7224 is already advertising this subnet towards you so you would be probably getting a conflict black holing of some traffic.
network 172.30.0.0
This is correct as its classful subnet and as such will be advertised like that.
This is probably due to the fact ebgp neigbour 169.254.45.17 ASN7224 already has this in it rib as a connected route and thus has a rib failure for 172.30.0.0
You need to find out why that neighbor is advertising that subnet
res
Paul
Kind Regards
Paul
Hello
bgp is stating even though it sees that prefix as valid its next hop isn't
With an AD of 200 I would check your ibgp peers
res
paul
Kind Regards
Paul
Here's the output from show version
show version
Cisco IOS XE Software, Version 16.03.01a
Cisco IOS Software [Denali], CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.1a, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 30-Sep-16 02:53 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ip-100-64-127-248 uptime is 7 hours, 51 minutes
Uptime for this control processor is 7 hours, 52 minutes
System returned to ROM by reload
System image file is "bootflash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ax
License Type: Default. No valid license found.
Next reload license Level: ax
cisco CSR1000V (VXE) processor (revision VXE) with 2042224K/3075K bytes of memory.
Processor board ID 9GOG3HYXLBE
1 Gigabit Ethernet interface
32768K bytes of non-volatile configuration memory.
3979824K bytes of physical memory.
7774207K bytes of virtual hard disk at bootflash:.
0K bytes of at webui:.
The device is an aws virtual appliance, with the cost including licensing, so am unsure why it says no valid license
I'll try and get the full config of the device done, but it will take me some time to take out sensitive info
