Problems with blocking Kazaa2
When I block Kazaa2 using the built-in kazaa2 pdlm on my ubr7223, it all works fine for a while (a few hours to a few days). But then, out of no where, it suddenly starts blocking other traffic, such as pop3 or DNS traffic. I can remove the kazaa2 block, and everything starts working again (including kazaa, which is NOT what I want). Anyone else having this issue, and how can I resove it? I can send a copy of my config if that would help.
mesuti
I tried to block kazaa2 and it was successful, but I don't know why it experiences you problems, I would propose you to try to block the fast-track
class-map X
match protocol fasttrack
also another solution is to block on http with string
match protocol http url "x-kazaa"
I'm not sure about the string x-kazaa, maybe you should sniff the kazaa packets before trying the http example.
hope it helps
Best Regards
Mesut Abdurrahmani
I'm already blocking fasttrack, as well as others. I don't have a problem blocking them; only Kazaa. Here is a snip from my config file reguarding the file-share blocking.
*snip*
class-map match-any p2p
match protocol gnutella
match protocol winmx
match protocol http url "\.hash=*"
match protocol http url "/.hash=*"
policy-map p2p
class p2p
police cir percent 1
exceed-action drop
violate-action drop
interface Cable2/0
ip nbar protocol-discovery
service-policy input p2p
service-policy output p2p
*end-snip*
If I add kazaa2 to this mix, pop3 gets blocked or limited (depending on how I have the policy-map setup). And, of course, no one can check their e-mail then, which equals VERY ill customers.
