Problems with DNS Name Resolutions. First Post!
Ebustos00
Hi everyone, im new here, and this is my first post, well... here is the issue...
I have two routers in a LAN, and are running EIGRP this is my topology:
As the title says, my problem is about DNS, so that R1 (Central) and R2 (Borde) are connected and are running EIGRP, when pinging www.cisco.com R2 (Borde) can resolve the address and name, when I try to ping www.cisco.com in R1 (Central) it solve, but cannot ping performs:
Central#ping cisco.com
Translating "cisco.com"...domain server (10.38.0.10) [OK]
Sending 5, 100-byte ICMP Echos to 198.133.219.25, timeout is 2 seconds:
Borde#ping www.cisco.com
Translating "www.cisco.com"...domain server (10.38.0.10) [OK]
Sending 5, 100-byte ICMP Echos to 23.3.240.170, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/8 ms
Then these are the configurations:
---------------------------------------BORDE CONFIGS-------------------------------------------
Building configuration...
Current configuration : 4165 bytes
version 12.4
hostname Borde
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
ip address 200.0.0.2 255.255.255.0
ip nat inside
clock rate 64000
router eigrp 100
redistribute connected
network 10.38.0.0 0.0.255.255
network 192.168.0.0
network 200.0.0.0
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
access-list 10 permit 192.168.0.0 0.0.0.255
access-list 10 permit 200.0.0.0 0.0.0.255
access-list 10 permit 172.16.20.0 0.0.0.255
access-list 10 permit 192.168.30.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
-----------------------------------CENTRAL CONFIGS-------------------------------------------
Current configuration : 1557 bytes
! Last configuration change at 16:27:25 UTC Thu Dec 6 2012
version 15.2
hostname Central
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip name-server 10.38.0.10
ip cef
license udi pid CISCO1941/K9 sn FTX162582J4
redundancy
interface GigabitEthernet0/0
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.20.1 255.255.255.0
duplex auto
speed auto
ip address 200.0.0.1 255.255.255.0
router eigrp 100
network 172.16.20.0 0.0.0.255
network 192.168.30.0
network 200.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
end
That's all the configurations, and the problem is that, how i can resolve this problem
sorry for the extensive post, but i need to put all the details about this.
Mohamed Sobair
Level 7
Level 7
On the Centeral Router add the following:
ip route 0.0.0.0 0.0.0.0  Serial0/0/0
Mohamed
