Cisco RV042 : issue with 1 wan connection and 1 bridged connection
dominic lazure
       hi,
i am trying to set up this : Connecting the sip trunk provider modem and my network on the rv042 and connect my phone system on it so he can access both my sip trunk and internet connection
I have 1 WAN modem from my sip trunk provider connected to the first WAN interface in the RV042.My network is connected to the second WAN interface programmed as a transparent bridge to link both lan segments together
however the link between the WAN2 interface and the network seems to go up and down and i cant ping my network gateway from a pc connected to the switchport of the RV042.
my sip trunk through the WAN1 interface is working fine
tech specs :
my network have the ip scheme of 192.168.15.X the gateway is 192.168.15.1
the cisco RV042 ip address is 192.168.15.151
i programmed the WAN2 interface as 192.168.15.152, my phone system .153
all i need is internet access to the phone system for email notification via a SMTP server
where am i wrong ?
paolo bevilacqua
Wrong forum, post in "small business - routers". You can move your post using the Actions panel on the right.
