Problems with GRE tunnels
Tusune
I'm here because today i've seen something in my topology that seems wrong :
I have 2 routers, each connected to the same vlan, so i've done HSRP on them. On each of them i have 4 GRE tunnels, and i wanted that when on the active HSRP router a tunnel go down, the HSRP priority decrease, but there is my problem : even when i cut links between ends of a GRE tunnel, it don't go down, i can't ping, but when i do a "show int tunnel 1" (for example), tunnel is up and line protocol is up.
Am i doing something wrong ? Or is this normal ? If normal, it's possible to make it going down when connectivity don't work ?
Thanks in advance.
mlund
Level 7
Level 7
Long time since i worked with tunnels, but i think ther where a command like "tunnel keepalive".
Without the keepalive the tunnel is up as long the destination is in the routingtable.
/Mikael
Ah thank you, exactly what i needed !
(config)# int tun 0
(config-if)# keepalive x
x is in seconds, so the interval between keepalives
Many thanks, it work :)
