Problems with PPP don´t work on Router C899G-LTE
rbalaguera19
I have a problem an is when i use this command encapsulation ppp on the interface cellular 0
interface Cellular0
description ### Access WVPN ###
ip vrf forwarding WAN
ip address x.x.x.x x 255.255.254.0
ip access-group SUC-WVPN-IN in
ip virtual-reassembly
load-interval 30
dialer in-band
dialer idle-timeout 600
dialer string gsm
dialer-group 1
async mode interactive
crypto map GRE_IPSEC
encapsulation ppp
Cellular0: Only SLIP encapsulation supported
How to configure ppp in this case? And the authentication for the interface cellular 0?
I use this IOS: 15.6.3M5
c800-universalk9-mz.SPA.156-3.M5.bin
I hope they can help me.
on a side note, 4G uses SLIP only as far as I recall. Try and 'offload' the cellular configuration to a dialer interface, which lets you use ppp:
interface Cellular0
ip address negotiated
load-interval 30
dialer in-band
dialer pool-member 1
dialer-group 1
interface Dialer1
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer string gsm
dialer-group 1
ppp authentication pap callin
ppp pap sent-username yourusername password 0 yourpassoword
Francesco Molino
Normally your have to change the chat-script like chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
Some documentation that'll help you:
https://www.cisco.com/c/en/us/td/docs/routers/access/1800/1861/software/feature/guide/mrwls_hspa.html#wp1323053
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
interface Cellular0
load-interval 30
dialer in-band
dialer-group 1
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer string gsm
dialer-group 1
Georg Pauwen,
Thanks so much, I only have a question and is the next: I have an ip address in the interface cellular. Can I use the same ip address in the interface Dialer 1 ?
yes, you can configure an IP address on the dialer interface. Just make sure you remove 'ip address negotiated' from the cellular interface...
