Problems with SVI
ibarra083
Hi:
I have a router 2901 with a EHWIC-D-8ESG-P card.
I configured vlans and DHCP pools but when I connect a PC to a port of the switch, th PC doesn´t adquire an IP addrees of the DHCP pool.
I know I have to configure SVI's in the router with IP addresses as gateways for the vlans. I have done it, but the vlan interface that I configure always appears as down down.
I applied the no shutdown command to the  vlan interface but this continues in the same status.
What do I have to do for resolving this problem???
Please, help me.
ahmad82pkn
Level 3
Level 3
have you configured that vlan in layer 2?
unless there is no active(up) port in that vlan, Vlan will not come up.(and it takes 1 to 2 minute to vlan to comeup once a port is in that particular vlan and something is connected to that port)
ahmad82pkn
Level 3
Level 3
