Problems with VPN Router ASR-1000
I have configured a DMVPN on my router ASR-1000, but the VPN does not stay active, performed the test on a router 3845 and it worked correctly, but the ASR VPN is not maintained, have any idea what may be happening .
Below I copy the configuration:
HUB
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key 6 $IPROOT$ address 0.0.0.0 0.0.0.0
crypto ipsec transform-set $VPNNET$ esp-3des esp-md5-hmac
crypto ipsec profile GREVPN
 set security-association lifetime seconds 86400
 set transform-set $VPNNET$
interface Tunnel0
 ip address 10.190.1.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip flow ingress
 ip nhrp map multicast dynamic
 ip nhrp network-id 10
 ip nhrp holdtime 600
 ip nhrp registration timeout 30
 no ip split-horizon eigrp 100
 ip tcp adjust-mss 1360
 qos pre-classify
 tunnel source 10.141.10.1
 tunnel mode gre multipoint
 tunnel protection ipsec profile GREVPN
Spoke
 encr 3des
 hash md5
 group 2
crypto isakmp key 6 $IPROOT$ address 10.141.10.1
interface Tunnel0
 bandwidth 1024
 ip address 10.190.1.2 255.255.255.0
 ip mtu 1480
 ip nhrp map multicast 10.141.10.1
 ip nhrp map 10.190.1.1 10.141.10.1
 ip nhrp nhs 10.190.1.1
 ip route-cache flow
 qos pre-classify
 tunnel source 10.141.10.13
 tunnel destination 10.141.10.1
May 26 11:14:54.748: ISAKMP:(0:31:SW:1): processing KE payload. message ID = 0
May 26 11:14:54.820: ISAKMP:(0:31:SW:1): processing NONCE payload. message ID = 0
May 26 11:14:54.820: ISAKMP:(0:31:SW:1):found peer pre-shared key matching 10.141.10.1
May 26 11:14:54.820: ISAKMP:(0:31:SW:1):SKEYID state generated
May 26 11:14:54.820: ISAKMP:(0:31:SW:1): processing vendor id payload
May 26 11:14:54.820: ISAKMP:(0:31:SW:1): vendor ID is Unity
May 26 11:14:54.820: ISAKMP:(0:31:SW:1): vendor ID is DPD
May 26 11:14:54.820: ISAKMP:(0:31:SW:1): speaking to another IOS box!
May 26 11:14:54.820: ISAKMP:(0:31:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
May 26 11:14:54.820: ISAKMP:(0:31:SW:1):Old State = IKE_I_MM4  New State = IKE_I_MM4
May 26 11:14:54.824: ISAKMP:(0:31:SW:1):Send initial contact
May 26 11:14:54.824: ISAKMP:(0:31:SW:1):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
May 26 11:14:54.824: ISAKMP (0:134217759): ID payload
        next-payload : 8
        type         : 1
        address      : 10.141.10.13
        protocol     : 17
        port         : 500
        length       : 12
May 26 11:14:54.824: ISAKMP:(0:31:SW:1):Total payload length: 12
May 26 11:14:54.828: ISAKMP:(0:31:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_KEY_EXCH
May 26 11:14:54.828: ISAKMP:(0:31:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
May 26 11:14:54.828: ISAKMP:(0:31:SW:1):Old State = IKE_I_MM4  New State = IKE_I_MM5
May 26 11:14:54.856: ISAKMP (0:134217759): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_KEY_EXCH
May 26 11:14:54.856: ISAKMP:(0:31:SW:1): processing ID payload. message ID = 0
May 26 11:14:54.856: ISAKMP (0:134217759): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 500
        length       : 12
May 26 11:14:54.856: ISAKMP:(0:31:SW:1):: peer matches *none* of the profiles
May 26 11:14:54.856: ISAKMP:(0:31:SW:1): processing HASH payload. message ID = 0
May 26 11:14:54.856: ISAKMP:(0:31:SW:1):SA authentication status:
        authenticated
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):SA has been authenticated with 10.141.10.1
May 26 11:14:54.860: ISAKMP: Trying to insert a peer 10.141.10.13/10.141.10.1/500/,  and inserted successfully 66271C54.
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):Old State = IKE_I_MM5  New State = IKE_I_MM6
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):Old State = IKE_I_MM6  New State = IKE_I_MM6
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):Old State = IKE_I_MM6  New State = IKE_P1_COMPLETE
May 26 11:14:54.860: ISAKMP:(0:31:SW:1):beginning Quick Mode exchange, M-ID of -1087210433
May 26 11:14:54.864: ISAKMP:(0:31:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
May 26 11:14:54.864: ISAKMP:(0:31:SW:1):Node -1087210433, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
May 26 11:14:54.864: ISAKMP:(0:31:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_I_QM1
May 26 11:14:54.864: ISAKMP:(0:31:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
May 26 11:14:54.864: ISAKMP:(0:31:SW:1):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
May 26 11:14:54.896: ISAKMP (0:134217759): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
May 26 11:14:54.896: ISAKMP:(0:31:SW:1): processing HASH payload. message ID = -1087210433
May 26 11:14:54.900: ISAKMP:(0:31:SW:1): processing SA payload. message ID = -1087210433
May 26 11:14:54.900: ISAKMP:(0:31:SW:1):Checking IPSec proposal 1
May 26 11:14:54.900: ISAKMP: transform 1, ESP_3DES
May 26 11:14:54.900: ISAKMP:   attributes in transform:
May 26 11:14:54.900: ISAKMP:      encaps is 1 (Tunnel)
May 26 11:14:54.900: ISAKMP:      SA life type in seconds
May 26 11:14:54.900: ISAKMP:      SA life duration (VPI) of  0x0 0x1 0x51 0x80
May 26 11:14:54.900: ISAKMP:      SA life type in kilobytes
May 26 11:14:54.900: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
May 26 11:14:54.900: ISAKMP:      authenticator is HMAC-MD5
May 26 11:14:54.900: ISAKMP:(0:31:SW:1):atts are acceptable.
May 26 11:14:54.900: ISAKMP:(0:31:SW:1): processing NONCE payload. message ID = -1087210433
May 26 11:14:54.900: ISAKMP:(0:31:SW:1): processing ID payload. message ID = -1087210433
May 26 11:14:54.900: ISAKMP: Locking peer struct 0x66271C54, IPSEC refcount 1 for for stuff_ke
May 26 11:14:54.900: ISAKMP:(0:31:SW:1): Creating IPSec SAs
May 26 11:14:54.900:         inbound SA from 10.141.10.1 to 10.141.10.13 (f/i)  0/ 0
        (proxy 10.141.10.1 to 10.141.10.13)
May 26 11:14:54.900:         has spi 0x565FB5B3 and conn_id 0 and flags 2
May 26 11:14:54.900:         lifetime of 86400 seconds
May 26 11:14:54.900:         lifetime of 4608000 kilobytes
May 26 11:14:54.904:         has client flags 0x0
May 26 11:14:54.904:         outbound SA from 10.141.10.13 to 10.141.10.1 (f/i) 0/0
        (proxy 10.141.10.13 to 10.141.10.1)
May 26 11:14:54.904:         has spi 1861909975 and conn_id 0 and flags A
May 26 11:14:54.904:         lifetime of 86400 seconds
May 26 11:14:54.904:         lifetime of 4608000 kilobytes
May 26 11:14:54.904: ISAKMP:(0:31:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
May 26 11:14:54.904: ISAKMP:(0:31:SW:1):deleting node -1087210433 error FALSE reason "No Error"
May 26 11:14:54.904: ISAKMP:(0:31:SW:1):Node -1087210433, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
May 26 11:14:54.904: ISAKMP:(0:31:SW:1):Old State = IKE_QM_I_QM1  New State = IKE_QM_PHASE2_COMPLETE
May 26 11:14:54.904: ISAKMP: Locking peer struct 0x66271C54, IPSEC refcount 2 for from create_transforms
May 26 11:14:54.904: ISAKMP: Unlocking IPSEC struct 0x66271C54 from create_transforms, count 1
May 26 11:15:40.911: ISAKMP:(0:30:SW:1):purging node -596953946
May 26 11:15:40.911: ISAKMP:(0:30:SW:1):purging node 68796087
May 26 11:15:44.899: ISAKMP:(0:31:SW:1):purging node -1087210433
May 26 11:15:50.919: ISAKMP:(0:30:SW:1):purging SA., sa=661832A8, delme=661832A8
May 26 11:18:37.820: ISAKMP (0:134217759): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
May 26 11:18:37.820: ISAKMP: set new node -467164272 to QM_IDLE
May 26 11:18:37.824: ISAKMP:(0:31:SW:1): processing HASH payload. message ID = -467164272
May 26 11:18:37.824: ISAKMP:(0:31:SW:1): processing DELETE payload. message ID = -467164272
May 26 11:18:37.824: ISAKMP:(0:31:SW:1):peer does not do paranoid keepalives.
May 26 11:18:37.824: ISAKMP:(0:31:SW:1):deleting node -467164272 error FALSE reason "Informational (in) state 1"
May 26 11:18:37.824: ISAKMP (0:134217759): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
May 26 11:18:37.824: ISAKMP: set new node -485344748 to QM_IDLE
May 26 11:18:37.824: ISAKMP:(0:31:SW:1): processing HASH payload. message ID = -485344748
May 26 11:18:37.824: ISAKMP:received payload type 18
May 26 11:18:37.824: ISAKMP:(0:31:SW:1): processing DELETE_WITH_REASON payload, message ID = -485344748, reason: Unknown delete reason!
May 26 11:18:37.824: ISAKMP:(0:31:SW:1):deleting SA reason "P1 delete notify (in)" state (I) QM_IDLE       (peer 10.141.10.1)
May 26 11:18:37.824: ISAKMP:(0:31:SW:1):deleting node -485344748 error FALSE reason "Informational (in) state 1"
May 26 11:18:37.828: ISAKMP: Unlocking IPSEC struct 0x66271C54 from delete_siblings, count 0
May 26 11:18:37.828: ISAKMP: set new node 1355382028 to QM_IDLE
May 26 11:18:37.828: ISAKMP:(0:31:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
May 26 11:18:37.828: ISAKMP:(0:31:SW:1):purging node 1355382028
May 26 11:18:37.828: ISAKMP:(0:31:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
May 26 11:18:37.828: ISAKMP:(0:31:SW:1):Old State = IKE_P1_COMPLETE  New State = IKE_DEST_SA
May 26 11:18:37.832: ISAKMP:(0:31:SW:1):deleting SA reason "No reason" state (I) QM_IDLE       (peer 10.141.10.1)
May 26 11:18:37.832: ISAKMP:(0:0:N/A:0):Can't decrement IKE Call Admisstion Control stat outgoing_active since it's already 0.
May 26 11:18:37.832: ISAKMP: Unlocking IKE struct 0x66271C54 for isadb_mark_sa_deleted(), count 0
May 26 11:18:37.832: ISAKMP: Deleting peer node by peer_reap for 10.141.10.1: 66271C54
May 26 11:18:37.832: ISAKMP:(0:31:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
May 26 11:18:37.832: ISAKMP:(0:31:SW:1):Old State = IKE_DEST_SA  New State = IKE_DEST_SA
May 26 11:18:54.962: ISAKMP: received ke message (1/1)
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0): SA request profile is (NULL)
May 26 11:18:54.962: ISAKMP: Created a peer struct for 10.141.10.1, peer port 500
May 26 11:18:54.962: ISAKMP: New peer created peer = 0x65BAAFEC peer_handle = 0x80000021
May 26 11:18:54.962: ISAKMP: Locking peer struct 0x65BAAFEC, IKE refcount 1 for isakmp_initiator
May 26 11:18:54.962: ISAKMP: local port 500, remote port 500
May 26 11:18:54.962: ISAKMP: set new node 0 to QM_IDLE
May 26 11:18:54.962: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 662B7E58
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0):Can not start Aggressive mode, trying Main mode.
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 10.141.10.1
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-07 ID
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-03 ID
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-02 ID
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0):Old State = IKE_READY  New State = IKE_I_MM1
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0): beginning Main Mode exchange
May 26 11:18:54.962: ISAKMP:(0:0:N/A:0): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_NO_STATE
May 26 11:18:55.002: ISAKMP (0:0): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_NO_STATE
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0):Old State = IKE_I_MM1  New State = IKE_I_MM2
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0): processing SA payload. message ID = 0
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0): processing vendor id payload
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0): vendor ID seems Unity/DPD but major 245 mismatch
May 26 11:18:55.002: ISAKMP (0:0): vendor ID is NAT-T v7
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 10.141.10.1
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0): local preshared key found
May 26 11:18:55.002: ISAKMP : Scanning profiles for xauth ...
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 1 against priority 1 policy
May 26 11:18:55.002: ISAKMP:      encryption 3DES-CBC
May 26 11:18:55.002: ISAKMP:      hash MD5
May 26 11:18:55.002: ISAKMP:      default group 2
May 26 11:18:55.002: ISAKMP:      auth pre-share
May 26 11:18:55.002: ISAKMP:      life type in seconds
May 26 11:18:55.002: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
May 26 11:18:55.002: ISAKMP:(0:0:N/A:0):atts are acceptable. Next payload is 0
May 26 11:18:55.058: ISAKMP:(0:32:SW:1): processing vendor id payload
May 26 11:18:55.058: ISAKMP:(0:32:SW:1): vendor ID seems Unity/DPD but major 245 mismatch
May 26 11:18:55.058: ISAKMP (0:134217760): vendor ID is NAT-T v7
May 26 11:18:55.058: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
May 26 11:18:55.058: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM2  New State = IKE_I_MM2
May 26 11:18:55.062: ISAKMP:(0:32:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_SA_SETUP
May 26 11:18:55.062: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
May 26 11:18:55.062: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM2  New State = IKE_I_MM3
May 26 11:18:55.098: ISAKMP (0:134217760): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_SA_SETUP
May 26 11:18:55.098: ISAKMP:(0:32:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
May 26 11:18:55.098: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM3  New State = IKE_I_MM4
May 26 11:18:55.098: ISAKMP:(0:32:SW:1): processing KE payload. message ID = 0
May 26 11:18:55.166: ISAKMP:(0:32:SW:1): processing NONCE payload. message ID = 0
May 26 11:18:55.166: ISAKMP:(0:32:SW:1):found peer pre-shared key matching 10.141.10.1
May 26 11:18:55.166: ISAKMP:(0:32:SW:1):SKEYID state generated
May 26 11:18:55.170: ISAKMP:(0:32:SW:1): processing vendor id payload
May 26 11:18:55.170: ISAKMP:(0:32:SW:1): vendor ID is Unity
May 26 11:18:55.170: ISAKMP:(0:32:SW:1): vendor ID is DPD
May 26 11:18:55.170: ISAKMP:(0:32:SW:1): speaking to another IOS box!
May 26 11:18:55.170: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
May 26 11:18:55.170: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM4  New State = IKE_I_MM4
May 26 11:18:55.170: ISAKMP:(0:32:SW:1):Send initial contact
May 26 11:18:55.170: ISAKMP:(0:32:SW:1):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
May 26 11:18:55.174: ISAKMP (0:134217760): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 500
        length       : 12
May 26 11:18:55.174: ISAKMP:(0:32:SW:1):Total payload length: 12
May 26 11:18:55.174: ISAKMP:(0:32:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_KEY_EXCH
May 26 11:18:55.174: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
May 26 11:18:55.174: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM4  New State = IKE_I_MM5
May 26 11:18:55.202: ISAKMP (0:134217760): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_KEY_EXCH
May 26 11:18:55.206: ISAKMP:(0:32:SW:1): processing ID payload. message ID = 0
May 26 11:18:55.206: ISAKMP (0:134217760): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 500
        length       : 12
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):: peer matches *none* of the profiles
May 26 11:18:55.206: ISAKMP:(0:32:SW:1): processing HASH payload. message ID = 0
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):SA authentication status:
        authenticated
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):SA has been authenticated with 10.141.10.1
May 26 11:18:55.206: ISAKMP: Trying to insert a peer 10.141.10.13/10.141.10.1/500/,  and inserted successfully 65BAAFEC.
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM5  New State = IKE_I_MM6
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM6  New State = IKE_I_MM6
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
May 26 11:18:55.206: ISAKMP:(0:32:SW:1):Old State = IKE_I_MM6  New State = IKE_P1_COMPLETE
May 26 11:18:55.210: ISAKMP:(0:32:SW:1):beginning Quick Mode exchange, M-ID of 517495394
May 26 11:18:55.210: ISAKMP:(0:32:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
May 26 11:18:55.210: ISAKMP:(0:32:SW:1):Node 517495394, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
May 26 11:18:55.210: ISAKMP:(0:32:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_I_QM1
May 26 11:18:55.210: ISAKMP:(0:32:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
May 26 11:18:55.210: ISAKMP:(0:32:SW:1):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
May 26 11:18:55.246: ISAKMP (0:134217760): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
May 26 11:18:55.246: ISAKMP:(0:32:SW:1): processing HASH payload. message ID = 517495394
May 26 11:18:55.246: ISAKMP:(0:32:SW:1): processing SA payload. message ID = 517495394
May 26 11:18:55.246: ISAKMP:(0:32:SW:1):Checking IPSec proposal 1
May 26 11:18:55.246: ISAKMP: transform 1, ESP_3DES
May 26 11:18:55.246: ISAKMP:   attributes in transform:
May 26 11:18:55.246: ISAKMP:      encaps is 1 (Tunnel)
May 26 11:18:55.246: ISAKMP:      SA life type in seconds
May 26 11:18:55.246: ISAKMP:      SA life duration (VPI) of  0x0 0x1 0x51 0x80
May 26 11:18:55.246: ISAKMP:      SA life type in kilobytes
May 26 11:18:55.246: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
May 26 11:18:55.246: ISAKMP:      authenticator is HMAC-MD5
May 26 11:18:55.246: ISAKMP:(0:32:SW:1):atts are acceptable.
May 26 11:18:55.246: ISAKMP:(0:32:SW:1): processing NONCE payload. message ID = 517495394
May 26 11:18:55.246: ISAKMP:(0:32:SW:1): processing ID payload. message ID = 517495394
May 26 11:18:55.250: ISAKMP: Locking peer struct 0x65BAAFEC, IPSEC refcount 1 for for stuff_ke
May 26 11:18:55.250: ISAKMP:(0:32:SW:1): Creating IPSec SAs
May 26 11:18:55.250:         inbound SA from 10.141.10.1 to 10.141.10.13 (f/i)  0/ 0
May 26 11:18:55.250:         has spi 0x677D14B2 and conn_id 0 and flags 2
May 26 11:18:55.250:         lifetime of 86400 seconds
May 26 11:18:55.250:         lifetime of 4608000 kilobytes
May 26 11:18:55.250:         has client flags 0x0
May 26 11:18:55.250:         outbound SA from 10.141.10.13 to 10.141.10.1 (f/i) 0/0
May 26 11:18:55.250:         has spi 35145355 and conn_id 0 and flags A
May 26 11:18:55.250: ISAKMP:(0:32:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
May 26 11:18:55.250: ISAKMP:(0:32:SW:1):deleting node 517495394 error FALSE reason "No Error"
May 26 11:18:55.250: ISAKMP:(0:32:SW:1):Node 517495394, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
May 26 11:18:55.250: ISAKMP:(0:32:SW:1):Old State = IKE_QM_I_QM1  New State = IKE_QM_PHASE2_COMPLETE
May 26 11:18:55.254: ISAKMP: Locking peer struct 0x65BAAFEC, IPSEC refcount 2 for from create_transforms
May 26 11:18:55.254: ISAKMP: Unlocking IPSEC struct 0x65BAAFEC from create_transforms, count 1
Thanks for the help you can lend
8 Replies 8
Leo Laohoo
Duplicate post.
Go here:  https://supportforums.cisco.com/discussion/12215736/problems-vpn-router-asr-1000
If you're not going to give solution, do not answer me.
Hello
I see a couple of possible misconfigurations between the hub and spoke(s)
Try and apply the following:
HUB
no ip next-hop-self eigrp 100
tunnel key 0
ip nhrp authentication PASSWORD
spoke
no crypto isakmp key 6 $IPROOT$ address 10.141.10.1
ip mtu 1400
no  tunnel destination 10.141.10.1
tunnel key 0
res
Paul
Kind Regards
Paul
Hello Paul Driver
Thanks for answer me
I did as it told me, but still lift the VPN. Without the VPN as I said before, I do ping spoke.
Jun  4 14:31:43.071: ISAKMP: Unlocking IPSEC struct 0x65CC5CB0 from delete_siblings, count 1
Jun  4 14:31:43.071: ISAKMP: received ke message (3/1)
Jun  4 14:31:43.071: ISAKMP: set new node 515332146 to QM_IDLE
Jun  4 14:31:43.071: ISAKMP:(0:2:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
Jun  4 14:31:43.071: ISAKMP:(0:2:SW:1):purging node 515332146
Jun  4 14:31:43.071: ISAKMP:(0:2:SW:1):Input = IKE_MESG_FROM_IPSEC, IKE_PHASE2_DEL
Jun  4 14:31:43.071: ISAKMP:(0:2:SW:1):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
Jun  4 14:31:47.071: ISAKMP:(0:2:SW:1):purging node -746539650
Jun  4 14:31:50.402: ISAKMP (0:134217730): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
Jun  4 14:31:50.406: ISAKMP: set new node -1119127387 to QM_IDLE
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1): processing HASH payload. message ID = -1119127387
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1): processing DELETE payload. message ID = -1119127387
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1):peer does not do paranoid keepalives.
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1):deleting node -1119127387 error FALSE reason "Informational (in) state 1"
Jun  4 14:31:50.406: ISAKMP (0:134217730): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
Jun  4 14:31:50.406: ISAKMP: set new node 455556831 to QM_IDLE
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1): processing HASH payload. message ID = 455556831
Jun  4 14:31:50.406: ISAKMP:received payload type 18
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1): processing DELETE_WITH_REASON payload, message ID = 455556831, reason: Unknown delete reason!
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1):deleting SA reason "P1 delete notify (in)" state (I) QM_IDLE       (peer 10.141.10.1)
Jun  4 14:31:50.406: ISAKMP:(0:2:SW:1):deleting node 455556831 error FALSE reason "Informational (in) state 1"
Jun  4 14:31:50.410: ISAKMP: Unlocking IPSEC struct 0x65CC5CB0 from delete_siblings, count 0
Jun  4 14:31:50.410: ISAKMP: set new node -1971206576 to QM_IDLE
Jun  4 14:31:50.410: ISAKMP:(0:2:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
Jun  4 14:31:50.410: ISAKMP:(0:2:SW:1):purging node -1971206576
Jun  4 14:31:50.410: ISAKMP:(0:2:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
Jun  4 14:31:50.410: ISAKMP:(0:2:SW:1):Old State = IKE_P1_COMPLETE  New State = IKE_DEST_SA
Jun  4 14:31:50.414: ISAKMP:(0:2:SW:1):deleting SA reason "No reason" state (I) QM_IDLE       (peer 10.141.10.1)
Jun  4 14:31:50.414: ISAKMP:(0:0:N/A:0):Can't decrement IKE Call Admisstion Control stat outgoing_active since it's already 0.
Jun  4 14:31:50.414: ISAKMP: Unlocking IKE struct 0x65CC5CB0 for isadb_mark_sa_deleted(), count 0
Jun  4 14:31:50.414: ISAKMP: Deleting peer node by peer_reap for 10.141.10.1: 65CC5CB0
Jun  4 14:31:50.414: ISAKMP:(0:2:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Jun  4 14:31:50.414: ISAKMP:(0:2:SW:1):Old State = IKE_DEST_SA  New State = IKE_DEST_SA
Jun  4 14:31:57.038: ISAKMP: received ke message (1/1)
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0): SA request profile is (NULL)
Jun  4 14:31:57.038: ISAKMP: Created a peer struct for 10.141.10.1, peer port 500
Jun  4 14:31:57.038: ISAKMP: New peer created peer = 0x65F72440 peer_handle = 0x80000004
Jun  4 14:31:57.038: ISAKMP: Locking peer struct 0x65F72440, IKE refcount 1 for isakmp_initiator
Jun  4 14:31:57.038: ISAKMP: local port 500, remote port 500
Jun  4 14:31:57.038: ISAKMP: set new node 0 to QM_IDLE
Jun  4 14:31:57.038: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 65E07C94
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0):Can not start Aggressive mode, trying Main mode.
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 10.141.10.1
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-07 ID
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-03 ID
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-02 ID
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0):Old State = IKE_READY  New State = IKE_I_MM1
Jun  4 14:31:57.038: ISAKMP:(0:0:N/A:0): beginning Main Mode exchange
Jun  4 14:31:57.042: ISAKMP:(0:0:N/A:0): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_NO_STATE
Jun  4 14:31:57.202: ISAKMP (0:0): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_NO_STATE
Jun  4 14:31:57.202: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Jun  4 14:31:57.202: ISAKMP:(0:0:N/A:0):Old State = IKE_I_MM1  New State = IKE_I_MM2
Jun  4 14:31:57.202: ISAKMP:(0:0:N/A:0): processing SA payload. message ID = 0
Jun  4 14:31:57.202: ISAKMP:(0:0:N/A:0): processing vendor id payload
Jun  4 14:31:57.202: ISAKMP:(0:0:N/A:0): vendor ID seems Unity/DPD but major 245 mismatch
Jun  4 14:31:57.202: ISAKMP (0:0): vendor ID is NAT-T v7
Jun  4 14:31:57.202: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 10.141.10.1
Jun  4 14:31:57.206: ISAKMP:(0:0:N/A:0): local preshared key found
Jun  4 14:31:57.206: ISAKMP : Scanning profiles for xauth ...
Jun  4 14:31:57.206: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 1 against priority 1 policy
Jun  4 14:31:57.206: ISAKMP:      encryption 3DES-CBC
Jun  4 14:31:57.206: ISAKMP:      hash MD5
Jun  4 14:31:57.206: ISAKMP:      default group 2
Jun  4 14:31:57.206: ISAKMP:      auth pre-share
Jun  4 14:31:57.206: ISAKMP:      life type in seconds
Jun  4 14:31:57.206: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
Jun  4 14:31:57.206: ISAKMP:(0:0:N/A:0):atts are acceptable. Next payload is 0
Jun  4 14:31:57.258: ISAKMP:(0:3:SW:1): processing vendor id payload
Jun  4 14:31:57.258: ISAKMP:(0:3:SW:1): vendor ID seems Unity/DPD but major 245 mismatch
Jun  4 14:31:57.258: ISAKMP (0:134217731): vendor ID is NAT-T v7
Jun  4 14:31:57.262: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Jun  4 14:31:57.262: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM2  New State = IKE_I_MM2
Jun  4 14:31:57.262: ISAKMP:(0:3:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_SA_SETUP
Jun  4 14:31:57.262: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Jun  4 14:31:57.262: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM2  New State = IKE_I_MM3
Jun  4 14:31:57.350: ISAKMP (0:134217731): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_SA_SETUP
Jun  4 14:31:57.354: ISAKMP:(0:3:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Jun  4 14:31:57.354: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM3  New State = IKE_I_MM4
Jun  4 14:31:57.354: ISAKMP:(0:3:SW:1): processing KE payload. message ID = 0
Jun  4 14:31:57.422: ISAKMP:(0:3:SW:1): processing NONCE payload. message ID = 0
Jun  4 14:31:57.422: ISAKMP:(0:3:SW:1):found peer pre-shared key matching 10.141.10.1
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1):SKEYID state generated
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1): processing vendor id payload
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1): vendor ID is Unity
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1): vendor ID is DPD
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1): speaking to another IOS box!
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM4  New State = IKE_I_MM4
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1):Send initial contact
Jun  4 14:31:57.426: ISAKMP:(0:3:SW:1):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
Jun  4 14:31:57.430: ISAKMP (0:134217731): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 500
        length       : 12
Jun  4 14:31:57.430: ISAKMP:(0:3:SW:1):Total payload length: 12
Jun  4 14:31:57.430: ISAKMP:(0:3:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) MM_KEY_EXCH
Jun  4 14:31:57.430: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Jun  4 14:31:57.430: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM4  New State = IKE_I_MM5
Jun  4 14:31:57.738: ISAKMP (0:134217731): received packet from 10.141.10.1 dport 500 sport 500 Global (I) MM_KEY_EXCH
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1): processing ID payload. message ID = 0
Jun  4 14:31:57.738: ISAKMP (0:134217731): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 500
        length       : 12
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):: peer matches *none* of the profiles
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1): processing HASH payload. message ID = 0
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):SA authentication status:
        authenticated
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):SA has been authenticated with 10.141.10.1
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):IKE_DPD is enabled, initializing timers
Jun  4 14:31:57.738: ISAKMP: Trying to insert a peer 10.141.10.13/10.141.10.1/500/,  and inserted successfully 65F72440.
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM5  New State = IKE_I_MM6
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Jun  4 14:31:57.738: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM6  New State = IKE_I_MM6
Jun  4 14:31:57.742: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Jun  4 14:31:57.742: ISAKMP:(0:3:SW:1):Old State = IKE_I_MM6  New State = IKE_P1_COMPLETE
Jun  4 14:31:57.742: ISAKMP:(0:3:SW:1):beginning Quick Mode exchange, M-ID of -76061614
Jun  4 14:31:57.742: ISAKMP:(0:3:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
Jun  4 14:31:57.742: ISAKMP:(0:3:SW:1):Node -76061614, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
Jun  4 14:31:57.742: ISAKMP:(0:3:SW:1):Old State = IKE_QM_READY  New State = IKE_QM_I_QM1
Jun  4 14:31:57.746: ISAKMP:(0:3:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
Jun  4 14:31:57.746: ISAKMP:(0:3:SW:1):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
Jun  4 14:31:58.106: ISAKMP (0:134217731): received packet from 10.141.10.1 dport 500 sport 500 Global (I) QM_IDLE
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1): processing HASH payload. message ID = -76061614
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1): processing SA payload. message ID = -76061614
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1):Checking IPSec proposal 1
Jun  4 14:31:58.110: ISAKMP: transform 1, ESP_3DES
Jun  4 14:31:58.110: ISAKMP:   attributes in transform:
Jun  4 14:31:58.110: ISAKMP:      encaps is 1 (Tunnel)
Jun  4 14:31:58.110: ISAKMP:      SA life type in seconds
Jun  4 14:31:58.110: ISAKMP:      SA life duration (basic) of 120
Jun  4 14:31:58.110: ISAKMP:      SA life type in kilobytes
Jun  4 14:31:58.110: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
Jun  4 14:31:58.110: ISAKMP:      authenticator is HMAC-SHA
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1):atts are acceptable.
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1): processing NONCE payload. message ID = -76061614
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1): processing ID payload. message ID = -76061614
Jun  4 14:31:58.110: ISAKMP: Locking peer struct 0x65F72440, IPSEC refcount 1 for for stuff_ke
Jun  4 14:31:58.110: ISAKMP:(0:3:SW:1): Creating IPSec SAs
Jun  4 14:31:58.114:         inbound SA from 10.141.10.1 to 10.141.10.13 (f/i)  0/ 0
Jun  4 14:31:58.114:         has spi 0x6AE01706 and conn_id 0 and flags 2
Jun  4 14:31:58.114:         lifetime of 120 seconds
Jun  4 14:31:58.114:         lifetime of 4608000 kilobytes
Jun  4 14:31:58.114:         has client flags 0x0
Jun  4 14:31:58.114:         outbound SA from 10.141.10.13 to 10.141.10.1 (f/i) 0/0
Jun  4 14:31:58.114:         has spi -1683084853 and conn_id 0 and flags A
Jun  4 14:31:58.114: ISAKMP:(0:3:SW:1): sending packet to 10.141.10.1 my_port 500 peer_port 500 (I) QM_IDLE
Jun  4 14:31:58.114: ISAKMP:(0:3:SW:1):deleting node -76061614 error FALSE reason "No Error"
Jun  4 14:31:58.114: ISAKMP:(0:3:SW:1):Node -76061614, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
Jun  4 14:31:58.114: ISAKMP:(0:3:SW:1):Old State = IKE_QM_I_QM1  New State = IKE_QM_PHASE2_COMPLETE
Jun  4 14:31:58.114: ISAKMP: Locking peer struct 0x65F72440, IPSEC refcount 2 for from create_transforms
Jun  4 14:31:58.114: ISAKMP: Unlocking IPSEC struct 0x65F72440 from create_transforms, count 1
Jun  4 14:32:00.761: ISAKMP:(0:2:SW:1):purging node 379003309
HUB------------------------------
interface Tunnel0
 no ip redirects
 ip mtu 1400
 ip flow ingress
 qos pre-classify
 tunnel source FastEthernet0/1/3.775
 tunnel key 10
 encr 3des
 hash md5
 group 2
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10
crypto ipsec security-association replay disable
crypto ipsec transform-set $VPNNET$ esp-3des esp-sha-hmac
 set security-association lifetime seconds 120
Spoke-----------------------------------------
 encr 3des
 hash md5
 group 2
crypto isakmp key $IPROOT$ address 0.0.0.0 0.0.0.0
interface Tunnel0
 bandwidth 1024
 no ip redirects
 ip mtu 1400
 ip route-cache flow
 qos pre-classify
 tunnel source FastEthernet0/1.775
 tunnel key 10
If you have additional recomendation, I would appreciate.
regards,
Hello
What routing are you using to reach the reach the internal networks?
Also can you post the output of these show commands:
sh crypto ipsec sa
sh crypto isakmp sa
sh dmvpn detail
sh ip nhrp
res
Paul
Kind Regards
Paul
Hello
I would like to talk to you about something, I have this same configuration in a backup link with a 3845 router and it is working without any problem.
sh crypto isakmp sa
dst             src             state          conn-id slot status
10.141.10.1     10.141.10.13    QM_IDLE             13    0 ACTIVE
sh crypto ipsec sa
interface: Tunnel0
    Crypto map tag: Tunnel0-head-0, local addr 10.141.10.13
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.141.10.13/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (10.141.10.1/255.255.255.255/47/0)
   current_peer 10.141.10.1 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 174, #pkts encrypt: 174, #pkts digest: 174
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 12, #recv errors 0
     local crypto endpt.: 10.141.10.13, remote crypto endpt.: 10.141.10.1
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/1.775
     current outbound spi: 0xDCE6326B(3706073707)
     inbound esp sas:
      spi: 0xECB44BAF(3971238831)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 3004, flow_id: FPGA:4, crypto map: Tunnel0-head-0
        sa timing: remaining key lifetime (k/sec): (4403252/55)
        IV size: 8 bytes
        replay detection support: N
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 3003, flow_id: FPGA:3, crypto map: Tunnel0-head-0
        sa timing: remaining key lifetime (k/sec): (4403251/55)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
sh ip nhrp
10.190.1.1/32 via 10.190.1.1, Tunnel0 created 00:55:29, never expire
  Type: static, Flags: authoritative used
  NBMA address: 10.141.10.1
sh dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket, T1 - Route Installed
        T2 - next-hop-override
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding
        UpDn Time --> Up or Down Time for a Tunnel
Hello
All looks okay now from a configuration perspective but you don't say if you are dynamically routing, advertising the inside physical interface and tunnel ip addresses - I would suggest to use eigrp and disable split horizon and next hop on the hub
and aslo apply this:
crypto ipsec transform-set strong esp-3des esp-md5-hmac
mode transport
res
Paul
Kind Regards
Paul
Hello Pual
Add the following settings:
crypto ipsec transform-set $ VPNNET $ esp-3des esp-md5-hmac
  transport mode
But still without looking up VPN :-(
I still think it may be the IOS
