Process 'set' action associated with class-map VOIP failed:
Andrew Schulz
I'm trying to set "service-policy output VOICE" to my FE0/0 interface and I continue to get the following error.
Process 'set' action associated with class-map VOIP failed: Set cos supported only with IEEE 802.1Q/ISL interfaces
Current configuration : 2737 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname FIFE2801
boot-start-marker
warm-reboot
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 4096 debugging
logging console critical
enable secret 5 $1$OsmI$mnA/0XdLqu8B3UCXSo4ex1
enable password 7 0701205A4B0C18161F1B130511
aaa new-model
aaa authentication login ciscoadmin group radius local
aaa session-id common
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
ip flow-cache timeout active 1
no ip bootp server
ip domain name piercecountylibrary.org
ip name-server 10.0.0.221
ip name-server 10.0.0.225
ip tcp synwait-time 10
class-map match-any VOIP
match access-group name VoiceTraffic
policy-map VOICE
class VOIP
  bandwidth percent 50
  set cos 5
class class-default
  fair-queue
interface FastEthernet0/0
ip address 172.16.200.25 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
speed 100
full-duplex
no mop enabled
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
description Data LAN
encapsulation dot1Q 1 native
ip address 10.0.25.101 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
interface FastEthernet0/1.2
description Voice LAN
encapsulation dot1Q 2
ip address 10.0.125.101 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
ip route 10.0.0.0 255.255.254.0 172.16.200.1
ip route 172.16.0.0 255.255.255.0 172.16.200.1
ip route 10.0.100.0 255.255.255.0 172.16.200.1
ip route 192.168.1.0 255.255.255.0 172.16.200.1
ip route 10.1.0.0 255.255.255.0 172.16.200.1
ip route 10.1.25.0 255.255.255.0 10.0.25.240
ip route 172.16.25.0 255.255.255.0 10.0.25.240
ip route 192.168.25.0 255.255.255.0 10.0.25.240
ip flow-export version 9
ip flow-export destination 10.0.0.5 9925
ip http server
ip http access-class 23
ip http timeout-policy idle 5 life 86400 requests 10000
ip access-list extended VoiceTraffic
permit ip 10.0.125.0 0.0.0.255 any
snmp-server community pacit RO
no cdp run
control-plane
line con 0
password 7 070D704B4C595D41
transport output telnet
line aux 0
line vty 0 4
privilege level 15
password 7 13074615095C406E
login authentication ciscoadmin
transport input telnet
line vty 5 15
privilege level 15
password 7 111A4825071A2B1C1433
scheduler allocate 20000 1000
ntp server 10.0.0.225
ntp server 10.0.0.221
end
Suggestions please.
Andrew
You need to get rid if the "set cos" within your policy map.
But if your ISP is expecting CoS settings then it sounds like you need to run a trunk on the outside interface. Sorry haven't setup VPLS before so can't be more specific.
Jon
7 Replies 7
Jon Marshall
CoS markings are contained within an 802.1q tag. If the interface is running 802.1q such as fa0/1 in your config then you can set CoS but if it isn't then it makes no sense because there is no place to write the CoS value in the packet header.
So for non 802.1q interfaces you need to use either IP Precedence or DSCP markings.
Jon
Thanks Jon,
I figured that was the case. Do I need to put the service-policy output VOICE on the WAN interface or can I put it on the LAN interface? My understanding is that it should be on the WAN or the ISP side of the router.
If you are trying to reserve bandwidth and set markings for the WAN then you need to apply it to the WAN interface. Generally speaking you would look to use DSCP markings when sending across a WAN.
Jon
Thanks for the reply Jon. Yes, I am wanting to reserve bandwidth and set CoS marking on the WAN link. I am not familiar with how that configuration would work or how to write it. Would you mind a sample using my config above???
Also, this is to Comcast VPLS and they state that all packets must be marked with 802.1p CoS values. With that, I am unclear as to what needs to change in my config to get this working.
Andrew
I setup my policy map with DSCP as follows:
policy-map VOICE
class VOIP
  set cos 5
  set dscp ef
class class-default
  fair-queue
Then attempted to set the service-policy output VOICE to FE0/0 and I still get the error.
Andrew
Jon
Got it. Removing the set cos did the trick. Thanks.
As for the trunk on the WAN side, I have been advised by Comcast that it is not needed.
Thanks again for the assistance.
