Proper EIGRP Configuration
mccmhtac1
I have a hybrid environment and I will do my best to explain:
OPTEMAN: 3 routers connected via a private subnet (/29) over the OPTEMAN: Site A, Site B, and HQ. Site A is a 3560 that is the gateway for two subnets: siteA1 and siteA2. SiteB is a 2621, and HQ is a 6509 w/ MFSC.
HQ also connects to 4 other sites via MPLS: SiteC, SiteD, SiteE, and Site F.
HQ has the server subnet, Internet connection, and connection to other services via MPLS.
I have basic EIGRP  setup on HQ, SiteA, and SiteB. So far only siteA and HQ are updating each other. Not sure why. I am looking for the best practice example of how I should setup my enterprise EIGRP. I currently use static routes between the sites. I would prefer to be able to setup EIGRP in parallel, the remove the static routes.
ajay chauhan
Level 7
Level 7
Brian,
would be better if you post one diagram.
Ajay
